Hi all
Just after some opinions on decent places to get a wheel alignment..
Would do myself, but my mates machine doesnt fit around my rear wheels as they are in the guards..
So.. where can i go..
tried pedders Phillip... cant get on hoist, because my car is too low, and the front bar will hit.
Went to Inline... and im guessin they do read these forums. but.. i was delt with in a rude manner... and i dont buy that.
Capital steering did my suspesnsion to start with and it had been back a few times to be fixed..
So.. im not tryin to diss anyone, but is there anywhere that do a good job, and can get my car onto the hoist?
Thanx guys.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/
Inline were rude to you? That's interesting.
Did you speak to Chris?
I think that Discount Tyres in Belco or Gunghalin (Which ever one(s) that Marc with the Stagea works at) was pretty well liked by the people on here. I wouldn't know as my car's always been to Inline.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3289378
I couldn't imagine Chris being rude to anyone, he was always very professional when I dealt with him.
Also, Marc doesn't work there anymore just in case anyone gets confused.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3289765
Chris, Inline, rude? Strange, although I will say it is run a bit differently to most workshops, but rude?
Im interested to know who you spoke to, cos Chris wouldnt be rude. He has done all of my suspension work and when it comes to wheel alignments, there is no way I would go anywhere else, hes a shit stirrer though.
But I guss not everyone can be happy. And im definately not having a go at you.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3289947
im not havin a pick at inline..
I walked in just to ask prices and times that wheel alignment can be done...
wasnt bein a dickhead.. just a casual person.. told him everyone here recommends him..
And just the way i was delt with, really didnt go well with me.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3290812
he never said it was chris when i last went there was more than one guy working there so maybe he just got a guy in a bad mood ??? either way similar to others i have found chris himself a cool person to deal with but if they gave that sort of service to me i personally wouldnt go back either.... luckily that has not happened :wave:
most places should be able to do a wheel alignment no dramas as you mentioned it's just a matter of if your car clears the hoists etc.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3290941
ahh ok. The only other person that works there is Carol, but she doesnt know cars at all. If you went there at the start of the year, I think he had someone working there, but im not sure.
Either way, you wouldnt be dissapointed with the outcome.
PS, they dont read the forums.
https://www.sau.com.au/forums/topic/181002-wheel-alignment/#findComment-3291304
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
