Hi people,
I just returned after 3 months from overseas and the poor Skyline will not start, I can't even get it out of the drive way, I thought it was the batterry and I bought a new one and it still won't start.
All it does is a tick, tick, tick noise from the front when i turn on the ignition, It won't even crank.
Any clues/ideas would be appreciated.
Thanks
https://www.sau.com.au/forums/topic/181008-my-nissan-wont-start/
Hi people,
Thanks
Huh...compression????....get your battery out and put it on charge....or use external battery with jump leads on electrical box.
Hmmmmm forgot to ask do you have a battery charger???? or another car to jump start?
Eug.
Another possibility is your immobiliser is still on, and its still cutting the fuel pump out.
I've had that issue on my PoS Brant, where the thing's gone on the fritz and enabled the battery (so my starter motor would tick over) but not removed the fuel pump cutout.
As people have said, you might need to get it roll started. I think (can someone confirm?) if you roll start the car you can do it without an alternator. The battery is new and so has charge; if it won't roll start then it could be the immobiliser.
Folks,
Thanks on the advice,
I think I know what the problem is now, I turned off the alarm with the key so it would not drive my neighbours crazy whilst I was gone, I will have to turn the alarm back on so that I know if it is actvated or not and then place my wifes new battery from NRMA and give it another try.
The car is heavy to push so I can clutch start it.
Thanks alot for the ideas people, great help.
jeez, I can't believe how much random comments have been given.
When starting, tick tick tick means the starter motor is clutching/not starting the car.
Just because the b82rz is new doesn't mean that it is charged fully. Make sure its charged, and she shoudl start.
The alarm may be on too, but the tick tick means starter
Where abouts are you?
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
