got a few parts lying around that we need to get rid of so here we go.
R32 Bits n Pieces
R32 GTR Wing (black) $100
560kg Engine Stand. Yellow and black $100 (pickup only)
S13 Stuff
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) -$400 {$350 box only}
6. STD S13 Suspension (front and rear dampers and springs) still on car - $100
7. S13 projector headlights with built in yellow foglight - $60
8. S13 Electric Window Control Box (controls all window functions ie auto) [[this is not the window switches]] - $60
9. S13 CA18DET coils. $30 each
10. S13 CA18DE Auto ECU [good for a spare] $10
11. EOI. late model 180 dash with digital odometer airbag model. $400
abs unit off late model 180sx $100
For more info or to buy stuff regarding R32 bits n pieces call Ross [0421 869 037]
To get the S13 stuff call Jimbo on [0405 160 740]
everything is located on north side of brisbane!
Edited by jeffers1987
https://www.sau.com.au/forums/topic/181011-r32s13-sparesmods/
R32 Bits n Pieces
1. Standard Rb20 injectors - $75
2. R32 Fibre Glass Rear Guards - $100
3. Standard Intake Plenum/Runners $100
4. Bilstein dampers and King Springs for front (very low very stiff) $150 (will sell with Gabs for 250)
5. GAB rear adjustable dampers with springs (quite firm) $150 (will sell with bilsteins for 250)
6. R32 GTR Wing (black) $200
7. RB20 Crossover Pipe with STD BOV - $50
8. Highflow RB25 turbo (R34 Compressor) - $500 (still on car available when new turbo goes on)
S13 Stuff
1. JIC Coilovers (6 months old) -$920
2. CA18DE + Auto Box (runs fine - 120rwhp on dyno log dyno) $350
3. CA18DET (in bits) great for rebuild has everything except exhaust manifold/turbo/loom - $200
4. CA18DET ECU - $50
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) - $500
6. STD S13 Suspension (front and rear dampers and springs) good condition - $100
7. S13 2 Eye projector headlights with built in yellow foglight - $100
pm sent regarding hi flo turbo (sold to me pending payment)
Oh prick!! I just saw that and was about to send him a PM.
Congratulations on the buy. PM me if it falls through :D
Free bump :sorcerer:
Thanks,
Abu
Edited by abu
Congratulations on the buy. PM me if it falls through :thumbsup:
Thanks,
Abu
hehe, i was bloody quick , no chance of the sale falling through on my end :D
dump pipe added to the list, damo that cash went in too buddy cheers i will ship the turbo off on monday when i should get a chance to get to aus post. cheers guys
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
