EXTRACTORS HVAE BEEN ORDERED, EXPECT DELIVERY IN ABOUT 2 WEEKS
Info
1989-98 Nissan Skyline R32, R33 - RB20, RB25 DOHC. 1 1/2" Primary 1 3/4" Secondary 2" Outlet D12
Standard finish is orange paint which reportedly burns off on first use. The extractors are mild steel.
cookm and Ryno have these extractors. Click here for more info
People who have ordered
Greg (me) - PAID
R33Glenn - PAID
NA_R33 - PAID
naiwiboo - PAID
_turtle_ - PAID
thanks for the sticky :(
For your info guys... When I bought my Cobe extractors (In NZ for my GTS25) I was told Cobe do not make different extractors for the RB20DE. The one set of extractors is used for both types of engine... I guess it's a happy medium.
What do you think of the extractors? Good increase in performance? any decrease?
I was pretty sure cookm posted some info on the different size pipe used for RB20 compared to RB25 extractors in the N/A thread but i might be mistaken. i'll confirm with Autopia.
here's that info:
1986-98 Nissan Skyline RB20 2000cc SOHC. 1 1/2" Primary 1 5/8" Secondary D6 234.82
1989-98 Nissan Skyline R32, R33 - RB20, RB25 DOHC. 1 1/2" Primary 1 3/4" Secondary 2" Outlet D12 279.45
so Ryno you were right: they make one set of extractors for the RB20DE and RB25DE, but they do make specific ones for the RB20E (sohc). if anyone has an RB20E (i think these were only in R33's as the shitty base model) you'd better let me know or you'll get the wrong ones!
I already had a 2 1/2 inch exhaust system before I got the extractors fitted, so I didn't notice a major leap in peak power. The big thing you'll notice is the improvement in torque, they make the engine far more flexible. I'm stoked with them, as I wasn't expecting much of an improvement.
When you get them they're painted bright orange, unfortunately after you run it the first time the orange paint flakes off. It's a shame, as I thought the orange pipes looked good sticking out the side of the engine.
sweet yeah i already have 2.5" exhaust as well, but any torque gains i'll be happy with. so i guess your extractors have gone a bit rusty now? i might look into getting them hpc coated or something to stop rust and to keep the heat in...
i wasnt expecting too much from extractors, maybe some more top end and a better sounding exhuast note.
if the torque increase to quite noticable, then that makes it even better!!! and considering the price as well, its a steal !
though i dont like orange=, chrome or black or me but its someting i can live with
Originally posted by NS2500
I'm in. Ready when you are.
Does anyone have any idea how long they take to fit? Is it something that's pretty straight forward?
Id say its pretty much unbolt the old one, and bolt on the new one.
Can i please get sum info if the extractors come with a new gasket and if the existing system has an O2 sensor on it ? i havent had a look at my extractors under the heat shield yet, i might have to get mine modified cos i have a new flanged CAT and maybe its not a direct fit but never the less i am all for it.
Cheers
:D
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
