EXTRACTORS HVAE BEEN ORDERED, EXPECT DELIVERY IN ABOUT 2 WEEKS
Info
1989-98 Nissan Skyline R32, R33 - RB20, RB25 DOHC. 1 1/2" Primary 1 3/4" Secondary 2" Outlet D12
Standard finish is orange paint which reportedly burns off on first use. The extractors are mild steel.
cookm and Ryno have these extractors. Click here for more info
People who have ordered
Greg (me) - PAID
R33Glenn - PAID
NA_R33 - PAID
naiwiboo - PAID
_turtle_ - PAID
thanks for the sticky :(
For your info guys... When I bought my Cobe extractors (In NZ for my GTS25) I was told Cobe do not make different extractors for the RB20DE. The one set of extractors is used for both types of engine... I guess it's a happy medium.
What do you think of the extractors? Good increase in performance? any decrease?
I was pretty sure cookm posted some info on the different size pipe used for RB20 compared to RB25 extractors in the N/A thread but i might be mistaken. i'll confirm with Autopia.
here's that info:
1986-98 Nissan Skyline RB20 2000cc SOHC. 1 1/2" Primary 1 5/8" Secondary D6 234.82
1989-98 Nissan Skyline R32, R33 - RB20, RB25 DOHC. 1 1/2" Primary 1 3/4" Secondary 2" Outlet D12 279.45
so Ryno you were right: they make one set of extractors for the RB20DE and RB25DE, but they do make specific ones for the RB20E (sohc). if anyone has an RB20E (i think these were only in R33's as the shitty base model) you'd better let me know or you'll get the wrong ones!
I already had a 2 1/2 inch exhaust system before I got the extractors fitted, so I didn't notice a major leap in peak power. The big thing you'll notice is the improvement in torque, they make the engine far more flexible. I'm stoked with them, as I wasn't expecting much of an improvement.
When you get them they're painted bright orange, unfortunately after you run it the first time the orange paint flakes off. It's a shame, as I thought the orange pipes looked good sticking out the side of the engine.
sweet yeah i already have 2.5" exhaust as well, but any torque gains i'll be happy with. so i guess your extractors have gone a bit rusty now? i might look into getting them hpc coated or something to stop rust and to keep the heat in...
i wasnt expecting too much from extractors, maybe some more top end and a better sounding exhuast note.
if the torque increase to quite noticable, then that makes it even better!!! and considering the price as well, its a steal !
though i dont like orange=, chrome or black or me but its someting i can live with
Originally posted by NS2500
I'm in. Ready when you are.
Does anyone have any idea how long they take to fit? Is it something that's pretty straight forward?
Id say its pretty much unbolt the old one, and bolt on the new one.
Can i please get sum info if the extractors come with a new gasket and if the existing system has an O2 sensor on it ? i havent had a look at my extractors under the heat shield yet, i might have to get mine modified cos i have a new flanged CAT and maybe its not a direct fit but never the less i am all for it.
Cheers
:D
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
