i've thought about fitting some more and decided that i want to dyno my car before and after so i might get ice or BMT or somewhere like that to fit them.
ps i paid for the extractors today :P rockie said they should be despatched early next week so you should receive them about 2 weeks from now. thanks everyone for your quick payment.
cheers
greg
does neone have an approxmimate price for fitting of these?? also am getting a apexi afc fairly soon along with a high flow airfilter and will have to get the car dyno'd is dyno tuning expensive??
Sorry dude, but i live in brisbane, melbournes a bit of a hike, hehe, nah i already have a place lined up to put mine on, i was just after a ball park figure for duno tuning thats all.
Cheers
John
Hey guys,
Just a bit of an update: the exchange rate was slightly better than expected (budgeted for 1.1000 and received 1.1135) but the transfer fee was slightly more (budgeted for $20 and payed $28). They pretty much even each other out, but I ended up making a huge profit of $8 :D
I had to pay for an extra set myself to make up the numbers, so if anyone (prefereably in melb) wants to buy it then pm me.
I think I've let most of you know already but I'm going on holidays for two weeks (leaving this saturday) so after then the best way if you need to contact me is on my mobile.
Regards
Greg
Sorry Clint I have to be fair here, neoGT-25 asked me first about 1 hour ago so I'll give him first go at them. If he deides against it or takes forever to get the money, then you'll be next in line. Alternatively I could auction them off? :D j/k
It cost me about $100 to get my Cobe extractors fitted, just to give you guys an idea... It took a little longer than I was expecting because they had to grind a side off all 12 of the washers, to miss the welds on the extractors.
yep its true, i'm currently in the cook islands :)
At the other end couldn't you just get them to weld a flange to it so it does bolt on to the cat? this would make it easier if you wanted to change your cat in the future. it sounds a bit dodgy about grinding them down, i thought they were meant to be a straight bolt on.
i had a look at the standard extractors today and they suck! piping is really small and bends obviously aren't mandrel done. also you guys should tighten your throttle cables. i took a fair bit of slack out of mine and it's much more responsive now :)
cheers
greg
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
