i've thought about fitting some more and decided that i want to dyno my car before and after so i might get ice or BMT or somewhere like that to fit them.
ps i paid for the extractors today :P rockie said they should be despatched early next week so you should receive them about 2 weeks from now. thanks everyone for your quick payment.
cheers
greg
does neone have an approxmimate price for fitting of these?? also am getting a apexi afc fairly soon along with a high flow airfilter and will have to get the car dyno'd is dyno tuning expensive??
Sorry dude, but i live in brisbane, melbournes a bit of a hike, hehe, nah i already have a place lined up to put mine on, i was just after a ball park figure for duno tuning thats all.
Cheers
John
Hey guys,
Just a bit of an update: the exchange rate was slightly better than expected (budgeted for 1.1000 and received 1.1135) but the transfer fee was slightly more (budgeted for $20 and payed $28). They pretty much even each other out, but I ended up making a huge profit of $8 :D
I had to pay for an extra set myself to make up the numbers, so if anyone (prefereably in melb) wants to buy it then pm me.
I think I've let most of you know already but I'm going on holidays for two weeks (leaving this saturday) so after then the best way if you need to contact me is on my mobile.
Regards
Greg
Sorry Clint I have to be fair here, neoGT-25 asked me first about 1 hour ago so I'll give him first go at them. If he deides against it or takes forever to get the money, then you'll be next in line. Alternatively I could auction them off? :D j/k
It cost me about $100 to get my Cobe extractors fitted, just to give you guys an idea... It took a little longer than I was expecting because they had to grind a side off all 12 of the washers, to miss the welds on the extractors.
yep its true, i'm currently in the cook islands :)
At the other end couldn't you just get them to weld a flange to it so it does bolt on to the cat? this would make it easier if you wanted to change your cat in the future. it sounds a bit dodgy about grinding them down, i thought they were meant to be a straight bolt on.
i had a look at the standard extractors today and they suck! piping is really small and bends obviously aren't mandrel done. also you guys should tighten your throttle cables. i took a fair bit of slack out of mine and it's much more responsive now :)
cheers
greg
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
