hi guys
i asked you about the install and tune SAFC few weeks ago
and everyone said they installed and tuned SAFC around $200
but the place i tried was over 400 and upto 700!!!!!!
i tried UNIGROUP they said 700...
and they said it wont improve much without boost controller..
so 700 for install and tune SAFC and boost controller...
anyone know anyplace cost around $200 to tune and installation?
cheers
paul
https://www.sau.com.au/forums/topic/181138-using-a-dyno/
hitman charge $250 for install and tune. i have never heard negative feedback about this workshop. every1 on this forum is recommending them
EDIT: don't know if that cost includes use of a dyno or not though
Edited by jaimzr33
https://www.sau.com.au/forums/topic/181138-using-a-dyno/#findComment-3292203
go see matt (hitman) at penrith
http://www.hitman.hm/index2.html
he will do it for much less, and do a good job of it too.
unigroup are severely overpriced anyway.
i sent the email to matt a week ago and they didnt get back to me yet... i should give them a call ..lol
https://www.sau.com.au/forums/topic/181138-using-a-dyno/#findComment-3311580
hey mate how are ya.?
yeh bud tell me about it hey. i got a quote for an install of safc mate.
195 bucks to install it cause it takes 2 and a half hours they said?
and couldnt quote me a dyno tune price because they couldnt tell me how long it will be on the dyno, and thats at 145 an hour.
so yeh i have heard guys on here getting much cheaper as well.
https://www.sau.com.au/forums/topic/181138-using-a-dyno/#findComment-3311606
Just to add, i had mine tuned-only at Unigroup for $150 but that was ages ago so i don't think they are overpriced but maybe included the price of the unit and installation as someone else already stated
i said to them i had safc..
i think they overpriced on me..
how long does it usally take to tune SAFC?
https://www.sau.com.au/forums/topic/181138-using-a-dyno/#findComment-3313495
On the topic, Ive got a quote of $650 to install a safc2, profec2 and a set of spark plugs thrown in gapped at 0.8mm and tune it from JEM moorebank. Does that sound resonable? I had a chat with Adam
Now I am most likely going to install the safc2 myself the spark plugs so I might get the price to come down. but yea 750 for a tune is ridiculous!
Also could someone guide me to a link on how to install a safc2 here on sau? Thanks
Edited by TramanBaba
https://www.sau.com.au/forums/topic/181138-using-a-dyno/#findComment-3313859
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
