i said to them i had safc..
i think they overpriced on me..
how long does it usally take to tune SAFC?
1 hr with an expereinced tuner, maybe less for hitman.
Not too much to change.
Okay just spoke to Matt(Hitman). And he quoted $250 fora safc2, and profec2 , both fit and tuned which I reckon is wayy more cheaper than some of the other quotes Ive had so far. So HITMAN! it is then.
That's fregan awesome by anyones standards !
Don't forget to post the results :(
wow i gotta call him stright away!!
did you tell him youve got the number from SAU??
I did mention that I got his number from SAU. Well i mentioned that to JEM as well who didnt seem to give 2 hoots about it. Anyways Hitman sounded a lot more pleasant and 'customer satisfactory'.. if there is anything like that.
i gave him a call and he quote me 250 for SAFC 1 and 50 for manual boost controller which is turbotech.
why did i get more that them? F!@#$K anyway its way cheaper than ive been quoted so far!
Probably because the installation is the easy part for both controllers.
then adjusting...
the electronic ones to adjust, you press buttons or turn dials to get the desired boost you want.
most have a display on them that shows you what you are setting it to.
the turbo tech is just a knob.
you turn it, do a run and see what boost it makes, then turn it some more and dyno again.. repeat until you have the desired boost level..
so it takes a few goes to get it "adjusted" the the setting you want.
that's why you got charged $50 extra.
then adjusting...
yes that makes sense
but 300 is still so~~~ cheap!!! very good!
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
