bored?
wanna listen to scanners online?
enter this url into either winamp or vlc
http://www.waix.net:8000/scanner
(with vlc its under open/open network, then enter url)
then download this document for reference to police codes (which is slightly out of date):
police_jobcodes_2006.pdf
or you can visit
http://warsug.info/viewtopic.php?t=3 and also check out the forum
its cool to have it on in teh background and everynow and then something interesting will happen
(the scanner unit itself drops out after 2 sec of no communication, and then will pick up anything it hears - police, fire, ambos, bus/train)
https://www.sau.com.au/forums/topic/181142-bored/
I used to have a scanner, i bought it from tandys for 200 bucks, Bloody good to listen to on the weekend nights. I heard things from kids throwing fire crackers at cars, crashes, police chases, a riot in cannington with over 100 people, a guy going from door to door asking for money, ALOT of domestics, and one where a skyline and a ferrari that were drag racing along the kwinana fwy at over 170kph across the narrows haha and one of a old commodore doing bout 150 through a booze bus haha what an idiot, and heaps more.
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3294295
A 'good' uhf will have this facility... at my old work i was having after work drinks listening to police freqs.
Best one I heard was about a 'ford falcon versus garage wall' lol... car chases are fun too...
Police have supposedl;y been going digital since pre-200... system has to many flaws, not happening anytime soon.
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3308735
When i picked my 32 up from the car yard it still had the standard radio/cd player in it from japan, their radio frequencies must be close to our emergency frequencies as i could hear ambulance chit chat through it. . . . nothing exciting happened :)
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3308810
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
