hi people got some standard gear for sale:
dump/fornt pipe:
series 1 manual ecu:
stock airbox, pefect condition:
turbo heat shield:
standard side mount intercooler, good nick:
just post some offers, need the stuff gone. in melbourne area. thanks
https://www.sau.com.au/forums/topic/181144-r33-gear/
not ebay. your a funny guy. dumpfront 50, ecu 100, airbox 50, cooler 40, heat sheild 10.
is the series 1 ecu remapable? and is it from a vct motor? if so, $100 freighted? to 7018.. its a $7.50 overnight bag..
let me know via pm.. cheers, Kent
https://www.sau.com.au/forums/topic/181144-r33-gear/#findComment-3292635
  • 1 month later...
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
