Micolour - Has Anyone Dealt With These Blokes?
If you want a top notch job and don't mind paying mick for his time then you will have an excellent job..
If you are a tightarse that wants a good cheap job i hope he tells you to f**k off because this mans work is amazing.
  • Replies 40
^^^ agreed.
Mick is a top bloke who does top notch work. You get wat you pay for,Simple as that.
If you want the best job then go and see him,
Details are in my sig.
once my car is done i will post up some before and after shots.
And anyone who knows my car knows how bad the rear gaurds are atm.
cheers
  • 1 year later...
Is there an email addy for Mick? I am os and need to drop him a line re some work on my "Field car"
pretty sure he does... but i dont have his business card on me at the moment... got about 100 @ home lol
someone will have one for sure
roy - pm me when u have sent and email to mick ... he generally doesnt check his email on a regular basis.. i can at least let him know you have sent him an email and ill get him follow it up.
micks the man... end of story..
i had a good chat to mick 2 weeks back getting a quote for my rear quarter. sure he is more expensive but from my conversation he went to detail as to exactly how he would go about it. I was also considering puttting on a kit while i was at it and he gave me his hoest opinions on the bodykits that are around and what to look out for. im quite particular about detail and surfacing and he answered all my questions and some. my car already has examples of the long term results of the cheaper/superficial repairs that was organised by my dad ages ago and is always an eyesore when im up close washing the car. If i can afford to do it properly the first time I would.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
