  • Replies 48
The Remapped RB25 ECU is the newest additon to the family... I have two projects nearly completed which will both have remapped ECU's... The end result is that it can be tuned exactly like I have been doing the RB20 ECUs for 6 years now. I did do a few of the RB25 ECUs a few years ago, but never knew where/how to the ECU done... till now!
I'll post details up as soon as they happen :(
Edited by Dr_Drift
I'll post details up as soon as they happen :P
Sounds good, looking forward to seeing some results.
Jeff from The Speed lab did my rb25 with R32 ecu (the easier and cheaper way then rechipping a 33 ecu) and i believe jeff said sam also does them.
Couldnt be happer with the result... my 33 ecu is now used as a paperweight
Dr-Drift looking forward for those details..
Simon-R32- Did you have any problems with the r32 ecu running on an rb25? Also what needed it to changed/hacked/re-wired etc to make it work for an r25 engine?
no probs what so ever, plugs straight in, however the 20 ecu cannot run the VCT, was no real issue for me as with the remap done, timing changed, boost raised it still has bucket loads of torque down low anyway!
Getting full boost at 2500 rpm, makes 215 rwkw on 0.9 bar with stock turbo. Drives like a dream, smooth clean power with awesome responce!
We've also done quite a few R32 ecus in R33s... we found the only wiring to be changed for street applications was when running an RB25 loom the idle switch needed to be wired in, only improved. We've also has some good success using the buddy club VTEC controller as a cheap VCT rpm output..
IMHO - Remap the R33 ECU is the best way to go...
we've talked a little in emails DrDrift - but one lingering "concern"
for those on a budget (ie, me) how much roughly for a remap to Stagea automatic ecu?
FYI; pinout on ecu is the same as for an R34GTT, although my 1997 engine is definately a non-Neo........
this is something I'd look at in 12months time or so
the 32 ecu WILL work on series 2.
Mine is a S1
Sam: have you got more info about the idle switch wiring? i havent done this and mine doesnt idle as it should some times
So it definetely works on the series II?? No problem with the different ignitor between series I and series II??
R33 ones are nailed! We are using the same boards as used to be in ash's R31 RB25 which was fully programable 5 years ago! We've only just been able to source the boards in the last few months...
Non-Neo Stagea is same price as R33, and AT is no problems, e-mail for quotes please.
Simon - Check the pinouts from R32 to R33 you will see the differences there.... I think PaulR33 has it on his page somewhere???
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
