Hi
I have the Evc 5 (USA) Evc 4 (JAP) installed in my GTT
I set up the controller as per instructions and it is overboosting
Does adjusting the offset do anything? I would expect that the standard offset of 100 would work fine
The hoses i'm certain are done correctly and the ebc is set to SW at the back for internal wastegates.
There are no leaks and cracks on the hoses (im pretty certain)
Cheers
Eric
https://www.sau.com.au/forums/topic/181168-evc-help/
i use one of these in my silvia read the manual a few times they are a little tricky to set up at first but once you get the hang of it its an awesome controller a higher offset will increase the boost faster so try turning the volume knob down alittle to compensate its hard how to explain how to use these things so just keep playing until you get it leave the offset at 100 or less and use the volume knobs to set your boost level and get it spot on then start playing with the offsets to make it boost harder..
https://www.sau.com.au/forums/topic/181168-evc-help/#findComment-3292319
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
