hey guys i am finally over da hump with only some supporting mods to make :rofl: =thankyou.
atm either installed or arriving, i have a
t3t4 stage 3 h/f tubo
safc II
twin plate clutch with os giken flywheel
3"exhaust, with screamer dump pipe
bilstein shocks-fr&rr strut bars
stock injectors(BUT NEEDS TO CHANGE)
BOSCH 040 PUMP AND NISMO FUEL REG
pod/cai
ssq bov
FMIC
sound system-dvd playa, custom boot with 2 12"1200watt subs, mono block 2000 watt, 4ch 100watt
turbo timer
nismo copper coated gasket = $$$$$$, almost died paying for it.
my question to u guys, if i have a fuel pump with stock injectors, how far can i go without blowing it. and i am thinking of going for 550cc's, can these take me to that magic 300kw+ number.
sry if theres not enough info, just a broad question.
:rofl:
ALSO IF THERES ANYONE OUT THERE WITH 550CC, PLS SEND ME A PM IF UR WANTING TO SELL, I LIVE ON THE SUNSHINE COAST.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/181239-fuel-pump-and-injectors/
i think you will run into trouble with the stock ecu maxing out before the injectors do
damn, ok, even with an safc II?
sweet, this is the stuff i need to know, to reach that 300kw.
any more suggestions or ways to improve would be appreciated
I have a nice big thread here.
http://www.skylinesaustralia.com/forums/in...=167572&hl=
Lots of stuff neesd to be done.
would it be at all possible to run 555ccers with the ecu and safc? or with a ramapped ecu?
and if no, what would be the largest injectors i could go. dont want to shell out $1000+ for a ecu of pfc?
sorry mate, but you won't get anywhere without an aftermarket ECU.
The Powerfc is cheap for $1000.
What other options have you got? $2400 for a Haltek? $2200 for a Autronic? $2300 for a Link?
If you "don't want to spend money", then you can't make your car go fast.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
