  • Replies 75
Originally posted by inark
lol yeah its always the ISP :D
when was the last time u reinstalled the modem driver? DFM560s arent the greatest modems. Are you using the latest driver? Have you tried locking the modem down to a more stable speed?
Tried a decent external modem?
Could also be the phoneline... things change over time, like line quality... ever seen a telstra techie van around the neighbourhood?
theres so many things that can affect the way it works
Have the latest driver.
Maximum Port speed: 115200
Phone line is new we just bought the house :D and the Phone point is like 2 m from my modem. So everything is fine. its ISP....99%.
Havent seen any vans. my modem is external.
Is iPrimus dial-up any good?
our dialup is as good as any others... wouldnt rate it any higher... if u were to come to primus with that modem i would not sign u up... however im not in sales unfortunately.
whcih chipset is it? RCV?
can u get me the ATIs of the modem?
98/ME
Control Panel>>Modem>>Diagnostics
Highlight the comport>>more info
ATI1
ATI3
ATI5
2k and XP
Control Panel>>Phone and modem>>modem
Highlight the modem>>Properties
Diagnostics>>Query modem
98/ME
ATI1
ATI3
ATI5
2k and XP
06-15-2003 21:20:58.559 - Session Statistics:
06-15-2003 21:20:58.559 - Reads : 30 bytes
06-15-2003 21:20:58.559 - Writes: 76 bytes
ATQ0V1E0 - OK
AT+GMM - COMMAND NOT SUPPORTED
AT+FCLASS=? - 0,1,2,1.0
AT#CLS=? - 0,1,2,8
AT+GCI? - COMMAND NOT SUPPORTED
AT+GCI=? - COMMAND NOT SUPPORTED
ATI1 - 168
ATI2 - OK
ATI3 - V2.210-V90_2M_DLS
ATI4 - V.90 & K56Flex Voice Modem
ATI5 - 040
ATI6 - RCV56DPF-PLL L8571A Rev 33.00/33.00
ATI7 - OK
and it takes like 30s or so to connect.
uve obviously got XP :D
what speeds are u connecting at??
on the advanced tab it will say something like extra initialization commands...
put in there
+ms=12,,,40000
if u connect at less than that then try
+ms=11
yes munkeh... yes they do :D
its a rockie so u shouldnt have too many issues... unless ur line is crap... which u can only get ur local call provider to check with a MOLDS test... altho ur ISP should be able to see what ur line is like and what the connections are like
put in there
+ms=12,,,40000
+ms=11
I connect at 49.2 Kbps.
Typed in "+ms=12,,,40000 " connected at 40.0 Kbps
thats right but it should make it more stable... one of the issues is that ur modem may be retraining..... retraining is where due to either line noise or poor driver support the modem changes modulation.... ie. u connect at 49.2k but during the connection it chops and changes (u wont see this tho)... the only way u will know its doing it is the fact that u may get loss in data flow or disconnected.
Ok, it didnt change anything... still slow... :D its ISP...
but that will slow u down to v34
i cant really do much in way of suggesting lock downs as i cant see ur connections... so it would be useless to use the v34 lockdown unless ur modem was retraining down that low anyway...
lol its physically slower but it might be more stable... i might be able to get u onto a family and friends plan if that still exists around here... i think its like 19.95/month unlimited hours and downloads... and then i can check ur connections and stuff.
Ok, i'll join. is that 12 month contract paying by quarters? coz i wouldnt want to get locked in if its sh!t connection.
