R32 GTR Vs S15 Jap Spec Vs R34 GTT
183 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I was talking standard turbos on both cars. Both cars will make similar power but the S15 is almost 250kg lighter.
By the same token you'll have to swap the injectors, the intercooler and need a powerfc to get that power figure on the SR20.
You'd almost get that sort of power from an R34 GTT just by upping the boost and leaving the rest alone. Leeman clocked just over 200rwkw with just a Greddy Boost Controller at 12psi on stock everything.
Edited by Howie
  • Replies 63
Posted Images
In White will look much nicer...
White looks great on them
From what i have read and from what i have driven, the R34 GTT is the pick from the S15 however if someone has the $$$ an GTR will be the ultimate.
Have you driven a GTR yet?
You can go spastic on them or just a few nice bits, eg;
spastic;
forged rods
forged pistons
head baffles
sump baffles
jun/n1 oil pump
n1 water pump
044 fuel pump
600cc injectors
nismo FPR
new turbo/s (easy $2500 there)
twin/triple plate clutch
gearset (when you smash the stocker)
better radiator
better FMIC
new ECU
exhaust
headwork, cams + cam gears
=a fair bit and a SHITload of power (easy 350awkw)
few nice bits;
new ECU
exhaust
EBC at 15 psi
clutch (if you like launching)
=not much at all, that on mine did 262 rwkw so it went fast enough to get around - dont forget with awd you get all the power to the ground
Good luck with it all
Hey Guys,
As most of you knew, I owned an R33 S2 GTSt with 200rw/kw for quite a few years and now almost 6 months driving a 2005 Pulsar Q I’m itching for a new power toy.
Basically I would LOVE an R34 GTR however its way out of my budget ($23,000) and so I have been test driving the following:
R32 GTR
Pros: Twin Turbo + 4WD + Excellent handling + Cheap (under $20,000)
Cons: 15 yr old + Most in poor condition + will need lots of $$$ for restoration (paint, interior .etc.)
S15 Jap Spec
Pros: New (current) shape + gorgeous interior + light weight + SR20DET (easier and cheaper to mod then RB's)
Cons: RWD (traction issues) + needs big work for big power
R34 GTT
Pros: New shape + Nice interior + Easy to get big power + Excellent handling
Cons: RWD (traction issues) + Heavy
I personally love the look of the the S15 and the R32 GTR but love the drive of the R34 GTT...
My question:
In regards to value for money and response to performance mods, which of these three cars should I go for?
NOTE: This will be a weekend car ONLY
Please feel free to comment
Regards,
Sarkis
Valid comparison although to say s15 has a gorgeous interior and GTT has nice interior is probably the wrong way round if not overstating both.
I like the s15's looks on the outside but since a worked SR20 sounds like pus I have to have an RB.
The costs in keeping the GTR running and modded are high.
I am biased towards the GTT since I have one although I did this same comparo when I bought it, albiet with a larger amount of money involved.
    • Believe it or not, it's about right, remember it's also the 4AT which is worth a good bit too. This sounds along just right with everything else ever posted here on a stock turbo at reasonable boost.
    • Ok, thanks, legends. I'm hoping I don't need to pull out the window regulator. I was thinking when the window is out, the regulator mechanism shouldn't interfere with the corner piece and then be able to be removed through the speaker hole. Fit the new corner piece and then refit the window, and Bob will still be our uncle.
    • Sounds spot on. My R33 gtst with a bit of boost made 162
    • So quick update.  got my Nistune done from CMS and was a smooth drive back.    Shane at CMS is good with his work and car runs fine. Was worried my fuel pressure might be cooked as my fuel leaks on a full tank 😂 but apparently she held pressure.    I asked him to install the boost controller so I don’t mess anything up, and he was happy to do it. Old solenoid is still in there but capped off.  I will remove that from the bracket next weekend.    for now…. I am happy with my 168 KW 😂😂  All she got is the 3” turbo back exhaust and the BC
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
