heres my GTR,
Has been for sale for a while on carsales & sick of tools ringing me with no intention of buying.
Looking to sell and buy a 34 GTR . :ermm:
95 model.
the car comes with the following extras:
18x9inch volk rims.
Nismo N1 dual exhaust system
Nismo white faced dials (speedo:320km & centre console).
nismo race spec brake pads
Pioneer MP3 player.
HKS speed cut defender.
just serviced with premium oils and dynoed at 235rwkw.
This is the 2nd R33 GTR that i have owned and its an absolutely beautiful car. 66,xxx km. Would suit anyone who is looking for a reliable and powerful daily driver or a solid base to start modifying from. the car came with service history from japan (done at Nissan in Japan) and I have been the only owner in Australia. $29,500 ONO
Ph: 0413390816, located Brisbane
Edited by marchGTR
https://www.sau.com.au/forums/topic/181268-r33-gtr/
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
