Hi Every body,
Does any one has a picture of the 03 BOSE headunit's back, I got the service manual but I am not a perfessional people, Hard to understand,
If we can have a pic to compare will make things easy.
Thanks every body.
Have a good weekend.
Frank
https://www.sau.com.au/forums/topic/181278-need-help-with-03-bose-hu/
ok take a snap of it and I'll help. what are you trying to do?
My friend in china got this on his VW, he told me it is very popular there, it is a MP3 decording box also working like an external CD exchange box.
It can connect IPOD by dock, USB key's with USB, also any audio device via 3.5mm,
conncet to the CD changer dock.
ALl function on Head UNit applied and also steeling wheel funcions.
Current product list almost cover all popular OEM and After units from US, German, France and Japan.
the most important is Price, less than AUD $100.
Only informaion to confirm are:
whether the head unit support external CD - Changer????----------I believe every one support.
the wire of the CD- changer-----------I believe you know what I mean by those unperfesonal word.
they also sell by some one in sydney for $155, I believe the seller come from china either.
Edited by Frank350GT
they do support cd stackers - clarion based or sony based. it not a standard protocol from waht I can see and the is no easy way to pin it out. there is a aux in in the unit and that is where I would go in.
Did you mean this stuff from jap?
They are very good either.
I am just looking for anyother option.
Cheers
thats near enough. there is an option for SAT radio on those. its one of the spare plugs on the bottom.
Thanks Chris.
Sorry I am not quite catch up.
Do you mean the setup on US form ragarding SAT Radio, They plug into a white 12-pin socket, does it also the CD-changer socket?
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
