Just had my brakes done at Perth Race brake, and i have to say, i'm super happy with the kind of care and attention Niel pays to his work. Top bloke!! I highly recommend him to anyone who needs to get their brakes done. And his prices are reasonable!!
https://www.sau.com.au/forums/topic/181286-just-had-my-brakes-done/
cant agree more Neil is a tops bloke and knows what he's talking about! goin to fit some custom braided lines i had him make for me tonight :)
ps it's actualy just Race Brakes phone number is 9390 0183 and unit 5/10 gillam drive kelmscott its best to call and arrange a time to go in because he's a one man show.
rofl. anyway, new brake pads, flush, and soon dba 4000 rotors. Nothing impressive mate. So not much of a setup !! hahahahaha.
I had my old brakes replaced about 4k ago, and the workshop that did it, screwed me around. When i tap my brakes the steering wheel will get a shudder, only when tapping. And it braked like a sissy, although the workshop guranteed me that it's made of kevlar bla bla bla.. stops better than most pads. #@$@#$, it cause a minor accident with an evo 9 resulting in 2k repairs. And then the workshop claimed i can't drive, that's the reason why i can't stop in time. WTF. Best thing is, if i remember correctly, the gts-t brakes came with shim plates. The workshop prolly threw it away, and my brakes squeal like a pig too.
My originals Trav.
Keefy, that sux mate, did the workshop fit the rotors as well? or is this prior to your work at Perth Race Brake? The squealing will be the pads, thats typical of brand new pads. If you change the pads when you get DBA4000's go for either Green Stuff or Ferodo.
Prior to Perth Race brakes. I've got Ferodos in them at the moment, so now just looking around for a new set of rotors. Neil has quoted me a decent price, so i'm going with him. The sqeual might be due to the absence of the shim plates. I need to go grab me a pair for the fronts. Nissan ones go for like $65. I wonder if i can get anything cheaper. Rofl.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
