CAR DETAILS:
1994 R33 series 1 gts-t
Power Mods:
hi-fow turbo (from AVO and has been freshly rebuilt to handle 20psi in July07) Cost $1800 + reconditioning
Microtech LTS-12 ECU & hand controller Cost $1800
Nippon Denso hi vloume fuel pump Cost $300
840cc Nismo injectors Cost $1400
Blitz SUS pod filter Cost $250
HKS FMIC & piping Cost $1800
GTR BOV Cost $100
Blitz d-EBC (dual electronic boost controller) $cost $600
HKS Iridium spark plugs Cost $160
Grex oil cooler Cost $1000
morroso catch can (not in pic of engine bay but since installed) $cost $200
Gates racing timing belt (installed at 87,000kms with new idler & tensioner pulleys & bolts) Cost $200
tomei adjustable exhaust cam gear Cost $160
full earthing kit Cost $50
nismo radiator cap Cost $80
HKS stainless dump pipe Cost $350
Blitz 80mm stainless front pipe Cost $350
X-Force 3"stainless cat Cost $220
Blitz NUR Spec-R 80mm cat back exhaust (with bolt in silencer) Cost $1100
Jim Berry (RACE CLUTCH)brass button clutch, one very tuff clutch!!! has 3400kg clamp pressure (installed 12months ago....less than 6000kms) Cost $1200
Handling Mods:
Front & rear Cusco strut braces Cost $350
Tein HA adj coilovers (height and 24step dampen adjustable) Cost $2800
Nismo 2-way LSD Cost $1800
HICAS removal bar Cost $150
Bridgestone 235/45/r17 front tyres BFGoodrich 255/40/r17 rear tyres Cost $1400
BBS 17x8 front an 17x9 Rear 2 piece forged rims were on car but was quoted $1700 per rim to replace but they're no longer made.
Bendix ultimate brake pads Cost $250
Slotted DBA rear rotors Cost $260
Braided brake lines Cost $500
Looks:
Genuine series 3 N1 GTR front bar Cost $1500
GTR grill Cost $200
400R skirts Cost $200
Veilside rear bar Cost $560
D-wing Cost $300
Nismo clear indicators in GTR bar aswell as side front 1/4 panels Cost $300
"skyline" shaved from the rear part between the indicators Cost $150
tinted windows (darkest legal) Cost $450
Interior:
Sports steering wheel / HKB boss kit Cost $280
Blitz guages(3 - water temp/oil temp/boost) Cost $300
Nismo 300km/h dash Cost $800
Blitz multispeed turbo timer Cost $260
Rockford forsgate head unit Cost $400
Earthquake 6" splits front $Cost 230
series 2 drivers & passanger seats
thats $22,300 worth of parts ALONE!!!! NOT INCLUDING the wheels, or labour for fitting, or painting, or the time spent on dyno tuneing
my loss, your gain :)
Power:
Dyno sheet for 259kw (at 17psi)
ET:
Best so far is 12.8 on street tyres at Heathcote on a 30+ degree day (only been to the strip twice)
$17,000 (open to offers)
With Rego till August 08 and a RWC
Has 90,000kms on it (48,000 km when I bought it in 2001).
This car has been maticulously maintained since the day I bought it in 2001, I was the first owner of it here in Oz, oil & oil filter changed every 6 months regardless of kms, all fluids have been changed within the last 12months. Timing belt/tensioner&idler pulleys bolts changed only a few months ago. New windscreen in Feburary. Hi-flow turbo just been freshly rebuilt in July
Any other questions please dont hesitate to ask, I'm sure ive forgotten something.....and happy to answer any queries
Located in Geelong, Victoria. Can bring car to Melbourne for serious buyer
Cheers
Berin
[email protected]
0417 546 384
Hi Berin,
The car looks really neat and tidy. Just a few technical questions about the car. How many kays did the car do on the old speedometer? How many kays has the standard motor been running 260kw? Does the new "gates" timing belt give the engine any more power over a nissan belt? The turbo can run 20psi has the standard engine been modified to suit the extra boost? In your signature picture the car looks to be involved in some sort of motorsport. How often do you do this?
Sorry for all the questions but there are so many stock cars out there with questionable service history that have been clocked in Japan and then live most of there life boosted to the edge of the limits of the standard engine.
Thanks
Tracey
Thanks for your detailed reply Berin,
I am a bit of a newby with forums and my boyfriend is about as sharp as a nuns nasty. I will run this info by my Dad "He works for Perkins Racing" and will get back to you if I am interested in making an offer.
Thanks again
Tracey
Reply
"Hi Tracey, I'm happy to answer any questions you might have,
1: when the new speedo was installed it was set to the same reading as the old one that was removed.
2: Its been running 260kw now for about 8 months an is still performing strong, its going in for a "check up" dyno tune on Monday, I do that every 6 months just to make sure everything is running the way it should.
3: The gates belt offers no power benifit but is 3 times stronger than a standard belt so it can withstand the output of the motor easily
4: The turbo can run 20psi, but I have not run it at that as it is a standard engine. 18psi is ok on the stock RB25's an 20psi would probably be ok, but im never one to push those limits. The power figures are made at 18psi and it performs strongly at this boost, but I mainly drive it set at 9psi. even at 9psi the car makes over 200kw
5: I've used it for 2 motokana days (where your lucky to get out of second gear an each run is shorter than 2 minutes) an even then it was on 9psi, because of the low speed nature of it theres no point in usung high boost settings. The car was always up to good operating temperature (oil & water) before I ever put it through any sort of event or dyno runs. Im very particular about my car an how I treat it, this is why it has been a constant strong performer with little to no faults ever happening to the car.
hope this has cleared a few things up for you, if you have any further questions, please dont hesitate to ask
Cheers
Berin"
your welcome tracey, If your dad has any other questions on his mind, or you for that matter, my mobile numbers there, give me a call an i'll answer everything as best I can, I can even put him onto they guy (Chris Dalton of Daltons Automotive) who has personally tuned an looked after the car for me for many years.
  • 3 weeks later...
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
