Hey guys i know this has been covered many times. I have a 3 inch cat back exhaust on my gtr. To get the most performance for the less amount of cash should i just gut the cat and get a 3.5 inch front pipe? I heard the dump pipes require removing the turbo's and i'm not really up for that at this stage. The car will only ever have about 250-270awkw. Thanks alot!
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/
you'll most likely get flamed for suggesting to remove your cat, considering it carries something like a $10 000 fine and is bad for the environment and that a hi flow cat does not rob you of much power
as a side note, there was an article in a not so long ago hot 4's / hpi where an r32 gtr had an exhaust upgrade, from stock to a full system, with back to back dyno runs. the stock put out 0.5rwkw more than the aftermarket custom made one. i do not understand why, they were shocked and hypothesised that the stock nissan system has extremely well engineered bends and diameters. but nothing definate. food for thought :D
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3294840
Hey,
Agreed - the fine isn't worth the performance (what can you buy for $10k?). A good cat's expensive, but if
250kW's being aimed for on stock turbos I'd be spending the money on a hi-flow cat so you can keep the flow
(kW) up with lower boost levels.
Incidentally, there's no way a stock GTR exhaust works better than any reasonable aftermarket system of 3" or above at 14psi on stock everything
(which is the minimum you'd be running for 250awkw on stock turbos). The more flow, the more difference between stock and a good
system. Seat-of-pants feel is a 25awkw difference at that level; haven't measured the 'before' but have driven from Queensland on a stock exhaust
and changed only the exhaust for that guesstimate.
Anyone that thinks a stock GTR exhaust works better than a 3" aftermarket one is welcome to buy my complete stock R32 v.spec exhaust
for $800 (the cost of a reasonable full 3" system ;))
Regards,
Saliya
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3294866
wow 800 for a full system to suit r32 gtr?? mate show me where!! The real question is since i already have a 3 inch catback will i gain a decent amount of power from adding a high flow cat and 3.5 inch front pipe. Also i wanted to know if an exhaust shop can change my dump pipes with no major dramas as i heard its a pain in the but!!
Also can you find front/dump pipes that are one piece?
http://www.nengun.com/hks/stainless-front-pipe-gtr
Does this item just bolt straight up the cat? If so i'd probably go somthing similar.
Edited by gtrboosting
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3294878
if i can find the article in the 1000 magazines at my brothers house (his magazine..) i will see if i can show it to u.
magazines and shops will bag the crap out of forums for having "know it alls" who dont know anything. then they write a 2-4 page article basically saying that the stock exhaust on a r32 gtr is as good as you need.
i have no opinion. IIRC it was same day, same dyno, reputable exhaust shop. ... :D
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3294947
there is a thread on here where someone had an r33 gtst with catback. he put on a split dump and gained a significant amount of power. many other ppl claimed the split dump gave superb top end bla bla. so the general answer will be 'yes'
however my mate (who had cat back r33) upgraded to split dump + boost and it didn't put down much on the dyno...
edit: logic will say that if you remove a restriction, such as cat / small front pipe, then you will reap a benefit. how much? back to back dyno it and put it up for everyone to see :D ..but no one really has the money / time to do that
Edited by InterCooL
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3294949
I would fit a front pipe and highflow cat, then save up and get some better turbos, or at least have steel wheels put in yours, trying to get 250rwkw out of stock 15y.o. turbos is a recipe for disaster. When you fit the turbos fit some dump pipes at the same time
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3295051
My 32 GTR came with 3inch front pipe, stock cat, then 3.5in apexi system. After putting in a 3.5 inch metalcat, the seat of the pants dyno said extra ~20kw. Car went from [email protected] psi to 242@13 psi (brought to boost down for extra safety margin a long time before the cat went on)
+1 for Adrianos comment - that's my plan.
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3295143
ok so what i want to know now is. If i buy a dump/front pipe in 1 like the hks one http://www.nengun.com/hks/stainless-front-pipe-gtr
Will an exhaust shop be able to fit the thing with out too many dramas? Will it cost a load in labour etc? I'm not looking to upgrade the turbo's any time soon but i dont want to buy a dump and front pipe seperatly when i can get a 2 in 1. Thanks!!!
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3295257
Im pretty sure anything you have to bolt directly onto the back of the turbos will require either removal of the turbos or engine and you fit it back into the car as one. You could just bolt up the first section of the dump/front pipe and fit the rest once it was back in the car.
CES make a similar combined dump/front pipe. Not sure if the akwardness of it all is worth it persoanlly. However i would be interested into hearing the outcome.
The other thing regarding that HPI article is that they are saying the CAT is the most restrictive item and if you replace that and leave the rest of the exhaust its not a bad alternative to a full system. Besides the stock gtr system is only a little smaller than a 3in system. I think from memory its 2.5in stock
Edited by Godzilla32
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3295266
On the 32 your dump pipes are not the best for flow.
Changing to bigger front pipes and geting a decent cat in there will help things flow better but not as well as they could - depending upon your power/torque target.
You could put new front pipes in yourself fairly easily - if the studs/nuts free up (lots of CRC or similar beforehand).
If you are planning a turbo upgrade in the future make sure you buy bits that go together well later.
Have fun
https://www.sau.com.au/forums/topic/181314-r32-gtr-exhaust/#findComment-3296198
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
