yes i was going to do a similar thing regarding pod filters and blowoff valves.
go tyo the wreckers and buy heaps of cheap rubbish bov and 20 dollar pod filters and just place them all in the engine bay. some cabletied to stuff and others still in the box. so clearly not doing anyhing.
then go for a cruise threw the city and get pulled up. it would be pretty funny to see what they did lol
The only time i get hassled by cops is when i break the law (in referance to cars)
I was searched and questioned once, after i had personally called the police to report a crime... Idiot cops couldn't understand the difference between behind the shops, and infront of the shops... Nor would they listen to anything we said... they even searched a muffin we threw in the bin... wtf is wrong with these people?
They don't have to have the 90 or 100 limit on them.
I asked that question before.
Also, they need to be displayed on the front or rear of the vehicle. Not directly along side the number plate.
And it's illegal to drill/cut a number plate to (It's called defacing!)
I've been printing off alot of legislation to keep in my car too.
Here is how I display my plates...
Yep, my car is dirty :D
I've been followed by the law a few times with them displayed like this and haven't been pulled over once. Wouldn't have a clue if it would conform to whatever rules they may have in place but they seem to work as they are. I just use the existing holes in the number plates and the P plates and blot the together using a M4 x 10mm bolt. Tight fit but does the job.
The only reason I do this is because I used to use those static stick on ones you put in the window, that in the previously mentioned letter was explained wasn't good enough... so I bolted the P plates to my number plates of my Subaru, the front number plate tucked somewhat conviniently under the front bumper. I figure if they can't see my Ps, they can't see my number plate either :O. Then I got the Skyline and decided to do the same thing
Have to say though, I was once told by a police person at school that magnetic plates where the best option, but if an officer on a bad day is going to book you for that, I don't think its worth the grief...
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
    • Not sure why but RBF660/700 or Castrol SRF is listed as DOT4, not 5.1.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
