Fs : Worn Os Giken Twin Plate Clutch Kit $350 Obo Open To Offers
Hi have for sale a OS giken twin plate clutch and os Giken lightened flywheel that is worn right down to the metal. Will cost $880 to reface both clutch plates ( quote from Direct Clutch Brisbane) this is out of my r33. if you buy this clutch and get it refaced you will pull away with pritty much a new twin plate clutch for around $1300. Alot cheaper than new! they are $2300 new. see for yourself
http://www.otomoto.com.au/osgiken/str_twin_plate.htm
$350 or best offer
mark
Edited by avalanche
  • 3 weeks later...
looks like the same one I've got, its for an RB25DET/R32 GTR or R32 GTS4 push type clutch.
if it is then tis a TS2BD, rebuild kit is about $800, depending on what's worn and needs replacing.
here's the official webpage for it, prices are listed: http://www.osgiken.co.jp/pro_clutch/clutch/ts2bd.html
I posted a thread about my one, might be worth reading if you're considering it... I absolutely love mine.
http://www.skylinesaustralia.com/forums/in...howtopic=182899
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
