Hey everyone,
I had planned to go with a pair of the Garrett 2860r-5 turbos but im now thinking to research what the next step up in potential power flow would be. The aforementioned turbos will potentially flow a combined 720hp. Which is plenty, but im still curious as to what the next step up is? Keeping in mind i do not want high mount/aftermarket manifolds and want to keep the twin setup. Ideally im after another garrett option, just the next one up the ladder.
Any thoughts will be much appreciated,
Deren
https://www.sau.com.au/forums/topic/181397-turbo-options/
Had planned on these myself though with Slide temporarily out of action, damit!!! might look at alternatives myself these were definitly no. 1 pick though.
Any bigger like the 2860 -10 (reputedly about gtrs size) and lag becomes an issue I believe unless running like 2.8 etc though if lag isnt an issue they might be okay, might have read the need a diferent manifold, turbo flange adapter whateva sure someone will correct that if I am wrong.
Going for response myself. :P
https://www.sau.com.au/forums/topic/181397-turbo-options/#findComment-3295707
Yeah i aggree with the regard to response, its important to be able to drive it comfortably on the street but i want the potential to crank them up for big power in the future. I guess 700+hp is big enough, maybe im just greedy :P I've noticed though that sometimes manufacturers say they will make xxxhp but when it comes down to it they are really pushed to the limit to produce these figures. Anyone had any real big numbers out of the 2860r-5's?
Deren
https://www.sau.com.au/forums/topic/181397-turbo-options/#findComment-3295722
Deren
"They will make"...not the correct wording...
Turbo's do not make the power.....lol
They will support....yes.
Max that is....350hp each..total of 700Hp
This is not at the wheels also.
Any larger than the -5's will see you in lag town....unless you have increased the capacity and put a set of poncams in.
Expect to see max...around 350Kw's at the wheels with the right mods on a stock motor on 1.5 Bar.
Good luck
https://www.sau.com.au/forums/topic/181397-turbo-options/#findComment-3296001
  • 1 month later...
On a 3L bottom? (26 head)
Anyone done -5's on the 3L? Or the -10's?
Im leaning towards -10's due to the fact its a 3L but very keen to hear opinions :(
https://www.sau.com.au/forums/topic/181397-turbo-options/#findComment-3373464
I realise they will not make the power. I also realise the power figure quoted isnt at the wheels :) Its a rough HP/flow figure. Its all going on a built rb26. 26 bottom end and 26 head. Planning on using the 2860-5's. I think i was just getting greedy :)
Deren
https://www.sau.com.au/forums/topic/181397-turbo-options/#findComment-3377257
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
