i just recently downloaded 210MG of what i thought was soldier of fortune 2. now the thing which pissed me off is that is took some 20 hours to download with a 56K modem, and when i opened it, it was in fact red alert 2. when i was downloading it from about 10 different people it said "soldier of fortune 2" when in fact it was red alert 2
not happy at all so now im getting medal of honour.
https://www.sau.com.au/forums/topic/1814-sof2/
Guest Diabolik1
I gave up using Kazaa, if you guys install Adaware on your system, youll notice that Kazaa adds heaps of spyware crap on your PC...and how many times have i downloaded game, and it turns out to be a totally different game..
And to top it all of, Kazaa hit me with a Virus that had me down for half a day.
I now use Direct Connect for all my downloads, including movies and games.
Anyway, check it out if you want:
http://www.neo-modus.com/
Goran
https://www.sau.com.au/forums/topic/1814-sof2/#findComment-38605
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
