Got one in mine, much better than the standard battery, lasts longer, more power.. though it is slightly higher than ther std battery, so you will have to make up a custom bracket to hold it down..
plus it is a sealed battery, so you can mount it anyway you want.. i also had to extend the -'ve and +'ve cables to reach..
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-382325
If you have the money go an Optima Yellow top gell cell battery i think around 400 bucks, has killer crank power AND is deep cycle -you can let it go dead flat over and over and recharge it and it will be fine. ideal for big stereo's. We put one on a v8 and the speed that it cranks compared to a new std battery is unbelievable. Getting one for the line soon.
Ive heard good and bad about odysee batts. Some ppl love em, others say they drop cells real quick and are crap.
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-383101
I had an Odyssey ES12V800, what a piece of crap! It dropped a cell in less than 6mths.
I spoke with a few Odyssey battery stockists & users, I was shocked to find a number of them had failed within 12mths! To make matters worse the Odyssey rep treated me like an idiot & only OK'd the warranty claim after it was proven (in person) that it had failed due to poor quality construction. I offered the rep to test my car's elec system to show him it wasn't a charging sytem fault that killed the battery too! I got my money back & now run a Yellow Top Optima ($405) - that hasn't missed a beat & starts the car in a flash even after sitting for a few wks :)
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-383690
I got a big odessey battery. Mainly got it for the stereo as they have alot more charge and ar more consistant. It is sooooooooooo noticeble as soon as oyu install it how quick the car kicks over on start up is incredicble compared to the standard battery. I am very impressed with mine, but price is not too good, i paid around the $400 mark for it.
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-383960
It's not the starting ability that's in question with these batteries. After all a 5sec 800CCA start pulse would want to do a good job! It's the quality control & longevity that's the issue! 6mths under "normal" useage isn't what I'd class as value for money :P I could accept the fact that I had a one-off bad one but when MANY other people report that same problem (including stockists) then I'd be taking my money elsewhere (as I did). The lack of customer service from Odyssey in OZ is the final nail in the coffin.
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-384156
Spose if yours farkd up then you copped bad service aswell, it wouldn't have gone down well eh... ah well i am happy with mine so far, its been in the car for about 3-4 months so i guess i'll know soon if it does the same thing, havn't had any problems yet, but i would have a liked to get an Optima battery but couldn't get one when i needed it. Ah well.
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-384293
Nothing wrong with normal batteries peoples, just sometimes, aprticularly with decent sound systems you need a good power source, and that only comes from a decent battery and is the reason i got mine. but i had heaps of problems with my standard battery anyway, would die after a few days of not driving it simply cos the alarm was armed so i had enough and got a newy, but went the better more exspensive battery for stereo cos i needed it.
https://www.sau.com.au/forums/topic/18142-odysee-batteries/#findComment-384338
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
