open the hood and look top behind the head lights unit
youll see hexagon shape bolt look plastic headlight adjuster.
turn the adjuster to lower your lights
where exactly is it?
i went to my car to take a look. cant find any hexagon shape bolt...
any pics woul be the best.
help me out.
Cheers.
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3296027
They should be located at the rear of your headlight. There should be two if I remember correctly. One to go left to right and the other to go up and down.
is it just behind the headlight? as in it is visible??
which one exactly is it?
pics would help a lot a lot...
i'm not going to drive out until i dim the lights.
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3296766
Are they the projector style headlights?
Or non-projector style?
If they are projector style, you will have to try and make shrouds to aim the beam lower or cutoff half the beam(www.hidplanet.com/forums) but it'll still look quite crappy
If tehy are non projector, get rid of them, they can't be used safely in your lights, you'll be blinding every car, cat, dog, cow, kangaroo and koala on the road :D
If you have a later model R33 GTR with Xenon lights standard though, the bulbs should be already aligned?
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3297794
R32 R33 R34 shouldnt be too different.
as far as i know R32 one is black bolt or hexagon look and R34 is white bolt or hexagon shape.
when you pot the bonnet up, just stand on side of your front wheel and look down at back of the head light unit
you know how to change lo beam? the adjuster is just above the lo beam cover. you dont have to duct down to look or put your hands inside the bonnet to feel. its visible from outside.
mine is R34 but i assume R33 should be same as R32 was very similar with R34.
but r34 doesnt have side way adjuster. only up and down.
hope you go through
cheers
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3298928
hexagon bolt that looks like a nail head with a plus on the end for phillips head screw driver
the stick out of the back of the headlight and there is one or two that face towards the sky from the top of the headlight
bit off topic
where can you find projector lens to do a retro fit?
can you just get the project lens itself without the socket? and mate that to the r33 socket?
can you get any old project lens that has a line in the middle or does it have to be xenon hid projector?
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3299147
bit off topic
Ebay :) or www.hidplanet.com/forums/
basically look for any projector HID lenses, usually from BMWs, Porsches, mercs, some nissans(350z, Murano)
Then measure your headlight size, i went for a Murano one because it's 2.5" lense would fit inside my light(R32)
https://www.sau.com.au/forums/topic/181436-hid/#findComment-3299800
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
