It doesn't matter what globes you have in your headlights, it should still adjust the light beam. There should be I think four on EACH side if I remember correctly. Two for the low beam and two for high beam.
If you try turning them, but doesn't move, try doing it more. As in keep turning it. One turn changes nearly f**k all, but it will aventually move the beam if you're turning the right one enough.
hexagon bolt that looks like a nail head with a plus on the end for phillips head screw driver
the stick out of the back of the headlight and there is one or two that face towards the sky from the top of the headlight
bit off topic
where can you find projector lens to do a retro fit?
can you just get the project lens itself without the socket? and mate that to the r33 socket?
can you get any old project lens that has a line in the middle or does it have to be xenon hid projector?
Just try looking on ebay.com. Not the Aussie one, but the US one. They usually have a few projectors and globes/ballasts for sale.
hidplanet.com/forums would be your best source of information.
https://www.sau.com.au/forums/topic/181436-hid/page/2/#findComment-3300801
But I only can see 2 on each side.
where is the other 2 on each side?
Adam, are you able to get pics???
Cheers.
https://www.sau.com.au/forums/topic/181436-hid/page/2/#findComment-3302299
Try looking down near the bottom of the headlight, if you can only see two then there's only two. :)
Have you tried turning these two bolts you've found yet? make sure you turn it enough (at least 5 turns to notice something, keep an eye on the beam when adjusting). If this doesn't move it then I guess you just have to wait till a R33 owner can help you out. I'm not too sure if the 33's and 32's are the same. :)
I hope you can get this beam moved down mate. Must hurt not being able to drive around after dark.
https://www.sau.com.au/forums/topic/181436-hid/page/2/#findComment-3302581
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
