Look guys,
This is a public forum dedicated to Skylines and the great people who own, worship or both the Skyline and everything that entails. This isnt a private message board for slagging one another off.
Im getting sick and tired of reading all this crap. You guys want to send each other love letters u do it privately rather than using these boards as your personal match making service.
ANY more posts whether it be in the middle of a thread or a new one will result in that thread being closed or moved no matter what the topic. If it happens more than once more after this warning you will be banned.
Enoughs enough.
https://www.sau.com.au/forums/topic/18145-terance-and-envy/
Poyz u can add urself to this list too... u seem to be getting a mention from a number of people in regards to your comments.
We arent here to argue and bitch. If you dont like someone PM or email them and discuss it with them and try and resolve it. Dont come on here and stir ppl up.
https://www.sau.com.au/forums/topic/18145-terance-and-envy/#findComment-378568
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
