i know thats what i mean some thing has to be broken or loose im thinkin lol
just dump the oil. See if there's anything in there and go from there. If you haven't changed the oil since it came in you should do it anyway. Should be changing all the fluids.
yea just have about to have a look now n see if theres any metel in it and if there isnt ?
Put new oil in it and try again. Some times heads will tap when they got old oil runnin through em. My old evo was a clasic for it.
Bugger.
take it from me, I've been swinging spanners for over 20 years and had my own big end go in an RB and the location of the noise absolutely stumped me even using a stethoscope, but it was a big end.
Get a proper mechanic to look at it ASAP. Stop running it and revving it or you could have a rod snap and punch it through the block/stuff the head or both.
I was a mechanic for a long time and stepped up to mechanical engineering and the best advice I can give is call one of those mobile guys to have a quick look, pay your money for their rime and then start getting quotes on the job and you will be glad for the money spent. I still build my own race engines so I'm not at all out of touch. Look in the thread below in my sig if you want to see some of the stuff that goes bad in RBs.
At the risk of being way off track, you haven't stated whether this happens only whilst drivng or when parked and revving as well. The reason I say this is because just after picking up my Stagea after purchase, it developed a knocking sound just like you are describing and I did the stethescope thing nd all sorts of buggering around. Even had a mate take it for a drive with all the console out so I could probe the gearbox and transfer case etc because it was only at very certain revs we could hear it. It actually turned out to be the uni joint on the front driveshaft and I only got it just before it snapped "shudders".
not thrust bearing happens when i press clutch lol guess its big end or cracked piston should find out tonight :ninja: looks liek im gonna haveto geta JUN 2.7 stroker for it ;):thumbsup:
Is it just when you push the clutch in?? Might just be a rattly multiplate clutch, i now many a twin plate are infamous for making the car sound like its gonna fall apart when engaged.
Best of luck mate, i hope not to have to a 'forced' rebuild myself... at least not in the next year or 2.
Might be a little late for my comment, but anyways.
I had a similar problem in my CA18det in my bluebird.
I thought it was a big end, cause it sounded familiar, as I have had a CA18 with stuffed big end before..
Sold the car for cheap as it was, to find out a week later that it was the lightened flywheel coming loose.
Yes I still have my legs luckily. :D
So yeah might be another thing to check...
But good luck anyways.
maka.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
