Ok well I've had my R32 gts-t (1992) for a year now and nothing has gone wrong until last night. first thing; started it up and there was a fair bit of smoke as it warmed up, which doesnt usually happen, then after a minute or so I noticed the speedo and odometer had stopped working. Its a Nismo 260kmh one and the tacho/other dials were working fine. Then I noticed my power steering had failed, and the HICAS dash light had come on, and stayed on. Popped the hood and couldnt see anything loose/obviously wrong.
So does anyone have any ideas as to what these symptoms could mean? I have no idea...only thing I can think of is that Dr Drift remapped my ecu about 2 weeks ago, he also put a new manual BC in because my EBC was spiking and maybe this has something to do with it.
Cheers for reading
https://www.sau.com.au/forums/topic/181479-couple-of-strange-failures/
If your speedo is not working then the hicas light will come on and the power steering will go heavy as hicas has lost it's speed signal from the speedo.
The speedo could be a cable or speedodrive problem.
You haven't put an r33 box in have you?
Your smoke problem is probably unrelated. It could be tune related or an AFM fault.
  • 2 months later...
Got exactly the same problem.
Just randomly the speedo stopped working and hicas light came on and steering went heavy. . weird thing is that every now and then the light turns off and steering goes light again then it goes heavy again?????
and im blowing smoke. . was something else and that was fixed but now it only smokes when i back off (valve seals have been replaced and still does it) and it blows smoke out of the catch can ONLY when boost is on when its not on its fine???
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
