Due to the volume of questions relating to installing the LEDs here is a basic "How To"
Please note the section on splaying out the leads on the globe and contacts in the base to ensure good electrical connection it also covers the orientation of the bulb this is a stumbling point for many people and results in 11 billion PM's about globes that don't work (but really do) :rolleyes:
Twist the bulb holder to remove (T10 and T5 shown)
Pull the bulb out of the holder, they *will* come out some are in tight
Sometimes the lead on the globe will fall into the recess in the plastic, splay it out slightly to guarantee electrical contact. Some of the bases are quite old and could also do with splaying. This is the number one reason for bulbs that "appear" not to work and actually are fine.
Fit the LED globe by pushing it into the base (T10 and T5 shown)
Twist the globe and holder back into the cluster (note the location of the black dot) Now this is the important bit; LEDs *only* work in one direction, so if it doesn't light up you need to turn the holder 180 degrees (note dot in second picture) Do *NOT* remove the bulb, just rotate the holder as then you won't get mixed up what direction you had the LED in the first place.
Plug everything back together after making sure everything lights up, congratulations you're done!!!!
https://www.sau.com.au/forums/topic/181486-globe-replacement-with-leds/
  • 3 months later...
  • 2 months later...
666Dan
Get your supplier to fit a bridge rectifier and you won't have to worry about polarity problems.
do you know what a bridge rectifier is... what it does? how it works... do u know what a diode is? how it works?
666Dan
It is possible, but you'd see 300% increase in price :thumbsup:...and as above, that's for making DC from AC so not much use in this instance
I'm trying this now. Dan, how much are your LED's? Tried a spare one that was sitting around the house, lasted 3 seconds before it blew... Now I'm struggling to sind some what would fit. Found one, but if yours are cheaper, I might buy some off you. I live in WA, how much would postage cost?
  • 10 months later...
You need to make sure it's got the right voltage rating, you need 12volt globes, or 4 x 3 volt in series for the voltage to work correctly, otherwise PING and she will blow.
I noticed in the pictures above that the globes look to be in series, so they would be 3-volt high-light LED's linked in series to allow them to take 12 Volts feed.
B.
hey dan the bulbs are in and work a treat. only question is that wen installed, on the right half of my tacho and speedo and lit up; the other half is either not lit or very dim. is there a fix to this or is it faulty globes?....
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
