to cut along story short
Got new rda slotted rotors front with some new generic pads (maxistop pads i think)
Got new rda slotter rotors rear with some other generic pads (mcb kevlar)
installed them as follows
cleaned all shims and applied orange anti squeel glue on them
chamfered all pads leading and traling edge on an angle
bled all 4
bed them in as descibred somehwre here on the forum (a few stops from 80 to 40 medium brake than some from 100 to 70 with hard pressure than drove for 10minutes to cool them before turning car off)
and they still freaking squeal, only when coming to a stop say 30km/h or less
WHYYYYYYYYYYYYY
getting braided lines within a week or 2 so will take them out and check if the pads are glazed, also will do a full brake fluid flush which should help pedal feel
any ideas??
rand up nissan and they want approx $180 for the anti squeal shim kit which i dont want to pay (mine are a bit rusty and thought maybe a new set with the copper grease will fix it if it was a cheap price)
https://www.sau.com.au/forums/topic/181505-tried-all-things-but-failed/
Try a real stop bed in session.
5 stops from about 120 to 20 then drive to cool off the discs.
personally I prefer racebrakes pads. Also consider chucking in a master cylinder stopper but those and lines won't stop the squeal.
forgot to mention also have a master cylinder stopper
i will need to bleed the abs unit too is that right?? any instructions on how to?
i will try the real bed in session when i get a chance but its hard to do coz people looking at you think you've lost it haha
Squealing 99% of the time has nothing to do with the friction material... its almost all the time caused by harmonics between the backing plate and the caliper itself.
Old trick, get some permatex and put a light coating on your backing plates... problem fixed! :)
There are three mating surfaces where you could apply the glue - pad to shim, shim to shim, and shim to piston. I *think* shim to piston is the critical one. I also left the grease between the shims. Cleaning it off may not have been a good idea.
Mate i'm in the same boat as you... i've tried bloody everything and spent so much fkn money and they squeak / squeel worse than ever. It's soo excrutiating!! I've tried 2 dif ABS places and both say the same "only so much you can do with skylines".. and both end up with same result. I've got new pads, new rotors and back plate thingy that ur suppose 2 try for skylines and its no use... still squeak.. i hate it!
My rear brakes (mainly rear right) are squealing at the moment.
I too just changed to RDA slotteds front and rear. I have EBC greenstuff on the front and they appear to be fine. It's the Bendix Ultimates on the rear that worry me (doesn't seem very popular this pad?). I am thinking that for the street these are just too hard or require a bit of temp to get them grippy. On the front they may be fine but the rear propbably wouldn't be doing much work. I might just try the Bendix CT or something else cheap in the rear and see how that goes.
A friend had RB74's in his car and no matter what combination of anti-squeel product or method of bedding we used they would squeel badly. Once you got them hot they were great but as soon as you cruised and went to stop that last little bit of light braking would just scream. Put the standard pads in and it was fine. Ended up changing brands on the front and putting standards in the rear.
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
