Hey Guys,
Starting a thread of posting your car's Audio Install's.. Show us your specs and your pictures
Use the template bellow.. And Insert your details and photos.
Have Fun :thumbsup:
 [i]Specs:[/i]
[b]Headunit:[/b]
[b]Front:[/b]
[b]Amp:[/b]
[b]6x9:[/b]
[b]Sub Amp:[/b]
[b]Sub:[/b]
[b]Capacitor:[/b]
[b]Wiring:[/b]
[i]Car:[/i]
[b]Make:[/b]
[b]Model:[/b]
[b]Year:[/b]
[i]Pictures:[/i]
<---Insert Here--->
Edited by fadinmist
https://www.sau.com.au/forums/topic/181506-your-audio-install-picturesspecs/
  • Replies 104
i'll start :thumbsup:
Specs:
Headunit: Pioneer DVD Touch-Screen
Front: MTX TDX-6502
Amp: MTX Thunder 3404
6x9: MTX TDX 6903
Sub Amp: MTX Thunder 3401
Sub: MTX Thunder 7500
Capacitor: None
Wiring: 4Ga Powers - 12GA Speaker Wire - 3 x Audioline RCAS
Car:
Make: Nissan
Model: Skyline R32
Year: 1993
Pictures:
Edited by fadinmist
Specs:
Headunit: Kenwood DDX6019
Front: Earthquake fc6.2 (600watt)
Amp: Earthquake ph2200.4 (4x175WRMS 4Ohm)
6x9: Earthquake EQ-693r (800watt)
Sub Amp: Earthquake PH5000d (5000 watt)
Sub: 2x Audiopipe 1000 WRMS DVC candy subs
Capacitor: 25 Farad power accoustic + 6 Farad power accoustic
Wiring: 1x run 0awg to 25 farad cap feeding monoblock, 1x run of 4awg to 6 farad cap feeding 4 channel
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Edited by nemz
Specs:
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Hahah NEMZ man, that car is going to flip once the bass hits :)
Nice install but, must sounds mint.
Thanks,
Abu
Edited by abu
Specs:
Headunit: Clarion DXZ766MP
Front: Alpine DDLinear splits
Amp: Alpine PDX-4150 digital amp
Rear: Alpine DDLinear's
Sub Amp: Alpine PDX-11000 digital amp
Sub: 2 x 12" Alpine Type R
Capacitor: 1 farad
Wiring: lots :thumbsup:
Car:
Make: Nissan
Model: Skyline R33
Year: 1994
Pictures:
Custom Boot:
post-15008-1187692025_thumb.jpg post-15008-1187692072_thumb.jpg post-15008-1187692109_thumb.jpg
Custom Parcel Shelf:
Tweeter Position:
Specs:
Headunit: Alpine IVA-D310E
Front stage: Boston Acoustic Pro60
Powered by: Audison LRx 2.5 amp
Sub: ID Max 12 Dual 2Ohm
Powered by: Audison LRx1.4 amp
Wiring: 0/4Ga + Stinger
Sound deadening: lotsa Dynamat
Built & tuned for SQ but it still pumps out some nice SPL :thumbsup:
Pictures:
post-25499-1187685828_thumb.jpg post-25499-1187685835_thumb.jpg post-25499-1187686200_thumb.jpg
Edited by G_Force
Specs:
Headunit: JVC DVD Unit and 7" VGA Touchscreen Moulded into the dash Air con controls moved to where the ashtray used to be
Front: Haha still stock
Amp: Running off the deck
6x9: stock rears
Sub Amp: 600wrms alpine
Sub: 2x 12" Alpine type S
Capacitor: no need they do more harm that good
Wiring: 2 Gauge to the amp rest for now is stock
Car:
Make: Nissan
Model: R32 Skyline
Year: 1990
Pictures: Still to come car is in the shop at the moment
Specs:
Headunit: Carputer, interface via Xenarc 7" touch screen
Front: Rainbow SLC265Kicks
Amp: TruTechnology 4ch
Sub: Rainbow 12" Amboss
Sound Deadening: Dynamat extreme to inside and outside doors skins, Dynaxorb mats
Car:
Make: R33 GTS-T Series II
Year: 1996
Pictures:
Edited by Trav33
Specs:
Car:
Year: 1996
Rainbows & Tru Tech... must sound sweeeetttt....
  • 1 month later...
is this worthy?
That's not bad, nice install, pity about the gear though :spank:
Maybe sell the gear, get a nice 1000watt RMS amp and a IDQ12 :P for some real kick arse sound :rofl:
Also lose the farrad capacitor on small systems like that they don't do much at all to be honest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
