Hey Guys,
Starting a thread of posting your car's Audio Install's.. Show us your specs and your pictures
Use the template bellow.. And Insert your details and photos.
Have Fun :thumbsup:
 [i]Specs:[/i]
[b]Headunit:[/b]
[b]Front:[/b]
[b]Amp:[/b]
[b]6x9:[/b]
[b]Sub Amp:[/b]
[b]Sub:[/b]
[b]Capacitor:[/b]
[b]Wiring:[/b]
[i]Car:[/i]
[b]Make:[/b]
[b]Model:[/b]
[b]Year:[/b]
[i]Pictures:[/i]
<---Insert Here--->
Edited by fadinmist
https://www.sau.com.au/forums/topic/181506-your-audio-install-picturesspecs/
  • Replies 104
i'll start :thumbsup:
Specs:
Headunit: Pioneer DVD Touch-Screen
Front: MTX TDX-6502
Amp: MTX Thunder 3404
6x9: MTX TDX 6903
Sub Amp: MTX Thunder 3401
Sub: MTX Thunder 7500
Capacitor: None
Wiring: 4Ga Powers - 12GA Speaker Wire - 3 x Audioline RCAS
Car:
Make: Nissan
Model: Skyline R32
Year: 1993
Pictures:
Edited by fadinmist
Specs:
Headunit: Kenwood DDX6019
Front: Earthquake fc6.2 (600watt)
Amp: Earthquake ph2200.4 (4x175WRMS 4Ohm)
6x9: Earthquake EQ-693r (800watt)
Sub Amp: Earthquake PH5000d (5000 watt)
Sub: 2x Audiopipe 1000 WRMS DVC candy subs
Capacitor: 25 Farad power accoustic + 6 Farad power accoustic
Wiring: 1x run 0awg to 25 farad cap feeding monoblock, 1x run of 4awg to 6 farad cap feeding 4 channel
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Edited by nemz
Specs:
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Hahah NEMZ man, that car is going to flip once the bass hits :)
Nice install but, must sounds mint.
Thanks,
Abu
Edited by abu
Specs:
Headunit: Clarion DXZ766MP
Front: Alpine DDLinear splits
Amp: Alpine PDX-4150 digital amp
Rear: Alpine DDLinear's
Sub Amp: Alpine PDX-11000 digital amp
Sub: 2 x 12" Alpine Type R
Capacitor: 1 farad
Wiring: lots :thumbsup:
Car:
Make: Nissan
Model: Skyline R33
Year: 1994
Pictures:
Custom Boot:
post-15008-1187692025_thumb.jpg post-15008-1187692072_thumb.jpg post-15008-1187692109_thumb.jpg
Custom Parcel Shelf:
Tweeter Position:
Specs:
Headunit: Alpine IVA-D310E
Front stage: Boston Acoustic Pro60
Powered by: Audison LRx 2.5 amp
Sub: ID Max 12 Dual 2Ohm
Powered by: Audison LRx1.4 amp
Wiring: 0/4Ga + Stinger
Sound deadening: lotsa Dynamat
Built & tuned for SQ but it still pumps out some nice SPL :thumbsup:
Pictures:
post-25499-1187685828_thumb.jpg post-25499-1187685835_thumb.jpg post-25499-1187686200_thumb.jpg
Edited by G_Force
Specs:
Headunit: JVC DVD Unit and 7" VGA Touchscreen Moulded into the dash Air con controls moved to where the ashtray used to be
Front: Haha still stock
Amp: Running off the deck
6x9: stock rears
Sub Amp: 600wrms alpine
Sub: 2x 12" Alpine type S
Capacitor: no need they do more harm that good
Wiring: 2 Gauge to the amp rest for now is stock
Car:
Make: Nissan
Model: R32 Skyline
Year: 1990
Pictures: Still to come car is in the shop at the moment
Specs:
Headunit: Carputer, interface via Xenarc 7" touch screen
Front: Rainbow SLC265Kicks
Amp: TruTechnology 4ch
Sub: Rainbow 12" Amboss
Sound Deadening: Dynamat extreme to inside and outside doors skins, Dynaxorb mats
Car:
Make: R33 GTS-T Series II
Year: 1996
Pictures:
Edited by Trav33
Specs:
Car:
Year: 1996
Rainbows & Tru Tech... must sound sweeeetttt....
  • 1 month later...
is this worthy?
That's not bad, nice install, pity about the gear though :spank:
Maybe sell the gear, get a nice 1000watt RMS amp and a IDQ12 :P for some real kick arse sound :rofl:
Also lose the farrad capacitor on small systems like that they don't do much at all to be honest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
