  • Replies 104
my space saver is gooooooooone
I have spare rims and tyres though for different events, so worst case I would leave the car where it is and go and get the spare rims and tools to jack the car up and put them on... Normally requires a friend or two as well... Hasn't happened yet but it wouldn't be that big of a deal for me...
as Jack said......you dont have to ditch the spare or jack, just be more creative in the install and at least carry a can of "fix a flat" stuff
I hate depending on others if my car gets a flat and certainly dont want to leave it on the road to go get help while the crims get leasure time for parts stripping.
  • 4 weeks later...
I've just finshed installing a set of new Boston PRO60 SE's in my R34 in Bi-wire/bi-amp formation and they sound fantastic. With over 70rms delivered to each woofer and tweeter in the car the sound stage delivers sounds I NEVER knew existed in songs! Surely worth the 1k or so they are worth
Next is to replace the subs I blew - Who knew you could actually blow 1000wrms subs!
Quality is always worth paying 4 isn't it, wait till you hear the sound guy or producer through the singers earphones
I asube by Bi-wire you mean one amp for left chanel and one for the right. I had my old civic (EZB00M 4 the old Central coasties) setup like that an I loved it. Will never mix my lefts and rights again...
and yes a 10W amp can blow up a 100W sub, seen it done. How you say .... DISTORTION, without going into the dynamics of cone movement vs Electrical input, distortion = heat, heat in subs and heat in amps. nasty nasty stuff....
Im plan'n one a stealth install as I drive mine daily and have little kids, I'm thinkn of a pair of 10" mounted where the back doors normally go (r33 coupe) in a glass box. does anyone know if theres any gear in there already.
Maybe whent the kidz get a bit older I bight think of a trio of 15z, hehe just dreamn
P.S.
l_uk3y
not pickn onya mate, its a common misbeleif. Caps are not useless, ... unless you don't need one that is!
So what does the cap do... easy fills in the transients. that is to say when a base beat hits hard, your amps pull lots of current, that current heats up your 0,2,4 guage cable, raising its resistance theirfore raising the voltage LOST over the cables (+ & -). that means less fuel 4 the amp,
the other advantage of a cap is speed. Batery can only put out so much current so fast (see CCA rating) caps are so much faster at this
so @ the end you get slightly more power to the subs(less voltage lost on pwr cables) but mostly more punch/impact from those big suddden hits ( easiest to notice with songs with lots of drums)
speaking of the old girl some quick details
2 x Alpine MRV F400's one left chanel one right ( both in bridged mode)
2 x 12" alpine ZR subs
5.25 MB quarts, up front run of amp
4" Pioneer in rear of deck(also cut cap in tweeter to disable) I like my sound from the front of the car... just my preference, afterall I don't go to a live gig and stand with my back to the band
1farad cap
P.S.
l_uk3y
1farad cap
R34 coupe has enough room if you do some metal cutting of the main body shell, which is defect in adelaide and most likely with ADR , everwhere ?
the volume is roughly enough for a sealed box sub depending on how crazy you go on remolding your rear panels , you could hide 8" or 6.5" and use factory panels with some retrim for the sound to get out.
ps. Hint if you own a R34 the steel panels behind the rear seat and in the rear sides are crazy heavy ...lol
the same thickensss Carbon fibre laminates save a ton of weight and are 5 times stronger then steel
without the rear one your rear end chassis flex will be noticed, I tested it in a very basic way..lol
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
