Dyno Day 22 September 2007 Saturday
By PotatoCake · Posted
Im not sure of it looks on your setup, but i cant see the exact pad style without taking everything apart -
I'm not trying to be rude - but can't you just go and take a peek at the pads you already have. I mean - they're right there, visible between the spokes of the wheels.
Bro as always, thank you. Would you know which is correct for the rears? Again, dba has 2 options: https://dba.com.au/product/rear-street-series-brake-pads-db1220ss/ & https://dba.com.au/product/rear-street-series-brake-pads-db1521ss/ -
Ok than i guess i will start to rip half the dash out to double check things. Thank you gtsboy
Yes i changed all the wiring,dash looms wiring from the ecm and tcm. Installed the tiptronic cluster, ecm, shift controle module even the tiptronic shifter. Only switch that i do t have is the steering wheel switch.
