R33 Series 2 Front Halfcut
A suitably thick, small piece of wood or plastic, taped onto the pedal where that stopper would go, will do you until it arrives in the mail.
By Dose Pipe Sutututu 路 Posted
Ahh Nissan things doing Nissan things. https://www.efisolutions.com.au/brake-pedal-stopper-s14-s15-r33-r34-v35-z33-wc34-a -
Hi folks. Haven't driven my Satgea for quite a while, connected the battery and noticed the brake lights are staying on. I've located the switch which is working. It seems when I have my foot off the brake the switch isn't touching the pedal. Before I loosen the nut and adjust it, just wanted to ask whether there should be a rubber block or something between the pedal and the switch. Just seems odd that I'd have to reposition the switch. Seems more likely to me there must be a rubber or something that's come off.
Yes customized and built from scratch pretty much after finally finding a local towbar supply and install place that was willing to do something "different". Very happy with it for sure 馃憣
Yeah. I'd need it for the extra miles required to get to and from the handful of E85 outlets.** **Not quite true. But the sparseness of them is good enough reason to stay on 98, for me at least.
