basicly i have a r33 series 2 motor in my vl and gearbox.
it came with a series 1 loom including coil pack etc.. also came with a chiped ecu, and matching z32 afm
so far i have added a jjr480 turbo rated at 480hp with a highmount and 35mm dump to 3inch
added a jj3 plenum which is 80mm i think, with a large front mount intercooler
ive added a rather big high flow fuel pump and fuel reg with guage,
i have bought a emanage ultimate but not fitted and tuned
what kind of power am i looking and generating here?
im hoping for 350hp at wheels
what do you think ? engine is roughly 66,000 kms in aparent good condition, and the chiped ecu is a essential nerve ecu
https://www.sau.com.au/forums/topic/181536-estimated-power/
No clue about the chipped ECU..
I'm pretty sure E-MANAGE can take after market injectors so my advice would be, upgrade the injectors to something like 550cc, and you already got the Z32, so try and push for about 250 - 280rwkw depending if the turbo can handle that.
Can the E-MANAGE run the Z32, and if not since the ECU is chipped to, can they work together (STD ECU Chipped + E-MANAGE + Z32)?
You should be able to make 220rwkw at a minimum if everything runs accordingly.
Is the car up and running yet?
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/181536-estimated-power/#findComment-3297194
the car is literaly days away, on sat they was fitting the piping and the throttle body which is the last of the engine, they just got to check the gtr brakes that was added, and they are putting in a vn lsd diff, it will be ready for powercruse which i have never been to yet.
the ecu i opened it up and it has a removable eprom, but i see no reason why it cant run with emanage. hmmm ill find out if emanage can run differnet afm's im assuming its a definate yes, my guess is worst case is you may not be able to pick a z32 from the list but at least adjust voltages to get it to work
https://www.sau.com.au/forums/topic/181536-estimated-power/#findComment-3297213
how much power can the stock injectors handle? they are 370 cc right on the series 2?
also other than the bolt ons, what is a safe power for the stock motor assuming its hand a good life at 66,000kms ?
https://www.sau.com.au/forums/topic/181536-estimated-power/#findComment-3299359
sorry little bit off topic, but does any one find it strange that my series 2 motor has a series 1 loom with coil pack etc.. also has a chiped ecu + z32, this is how i recived it all together
not a problem running the s1 loom on a s2 motor.
my mate runs a s1 loom on a neo r34 motor in his r33. he even runs an s1 pfc.
only difference is the wiring around the igniter pack.
https://www.sau.com.au/forums/topic/181536-estimated-power/#findComment-3316502
good ECU choice. sell your Z32 AFM off for $200 and get a good tune on the microtech. I see your on the gold coast, give Matt Spry @ PITS a call. best on the coast. get at least 555cc injectors. dont put more than 260 or 270rwkw through a stock rb25 or you risk kaboom. a nice responsive 250rwkw will be a tonne of power for the street.
https://www.sau.com.au/forums/topic/181536-estimated-power/#findComment-3317200
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
