Hi ppl,
I am ripping my hair out at this point. After having spent hours trying to figure this problem out and a few hours of research on google I am still at a loss. I am not the full bottle on turbos and am really in need of some help as I would like to save a mate some money.
Here is the problem.......
We have stock boost pressure e.g. We are still managing to boost to 7.5-8psi which as I beleive is the stock boost. But the second stage is totally missing. We had previously had the car up around 19psi and even clocked the 20 mark once or twice. REgularly it is running at 15 psi but it can easily take the 19-20's.
Here is what happened and also what I have already covered. I will also include what the vehical has as it is fairly modded. I can get more specific with the brands and anything else you guys may need eg. photos ect. Whatever you need to help me solve this.
The Scenario:
My mate stopped in for fuel (using 98) everything was working fine. Started the car and instantly noticed a difference in the motors sound. But just a lack of boost and also the air filter started making a heavy sucking sound as if it was blocked.
What the car has:
Aftermarket frontmount intercooler
High Flow Pod Filter
High Flow Cat with 2.5 exhaust and high flow muffler
HKS Electronic Controlled boost valve with three stage setting HIGH LOW and MANUAL (Manual setting is what cranks this bad boy to over 19psi)
Nice set of fat 17's with new rubber
Manual with heavy duty clutch
Imported from Japan with only 48k on the clock.
High flow fuel pump for extra boost
Decent branded BOV (Forgot to check Brand) Its a flutter valve too.
Motor in good shape (Not blowing smoke or using oil)
What I have done so far:
Cleaned Air Filter
Romoved all intake pipes
Checked blades on turbo-all good
Checked turbo movement-all good
Checked wastegate actuator-seemed slightly hard to move to me but I don't actually know how hard they have to work to move.
I replaced a few hoses that werent in to great shape
Checked wastegate movement-all good
Boost valve seems to be operating as normal-could be wrong
Thats about all I have done. So any help with some more test I could do or maybe if someone has had the same or similar problem that would be great. My mates car is a weapon and its a shame to see such a nice car going to waste. I am a commodore lover and even I want to fix this thing cause its such a great car to drive in. Probably the only turbo I would every buy oh unless it was a VL Calais ;P
Cheers ppl,
Simon.
Edited by simongilbert
https://www.sau.com.au/forums/topic/181544-r33-boost-pressure-problem/
i didnt see a mention of what turbo your running. Your not running 20psi on the standard turbo are you???
Me too.
I hope to GOD you aren't running that on a stock turbo.
Anything above 13psi will destroy it.
Um fairly certain it isn't a stock turbo. I think it has stainless steel blades. definitely not ceramic blades. All blades are still intact and turbo spools up just fine. It was regularly running 15 psi. And if we wnated some fun we would bost it up to 19. It lost traction in fourth......nice car. Anyway I can get some more specific specs for you. I wil see my mate to day and will get all the goods. The whole car has been worked by some asian bloke in sydney. MY mate flew there to buy it. I am not sure but I think that the motor may have had work done also. Thanks for your replies. Will get back to you.
LOL if its stock turbo hahaha
Metal blades would indicate a high flow. Best to check it before you blow it.
Thanks,
Abu
How would I be able to tell if it is high flow. HaHa....before we blow it.......if we havent already. But I think turbo is stil in perfect condition. At the moment due to our lack f boost its not going to be at all possible to blow.
Turbo: HKS GT2540 46T Max 30.1 PSI Limited by Compressor Wheel Speed
Bov: Blitz Flutter
Intercooler: T-Trust (Its a bigone)
Boost Control: HKS EVC
Exhaust: Definitely High Flow still not sure of brands
Boost Gauge: Factory Cluster Gauge and T-Sport Gauge with Max 30PSI
Engine: RB25DET
Year: 1996
Fuel: High Flow/Fast Flow Bosch
ECU: HKS2540 46T Installed by Garage Saurus
Injectors: Can't really tell but do look aftermarket.
So lads here is some more information for you. Thanks in advance......a carton is on its way for whoever solves this problem!! :)
ahh, the ecu wont be a hks 2540,odds are it would be a power fc if it was built in aus. first places i would look by the description you've written would be the inlet pipe from the filter to the turbo, in between the filter and theafm (might have something in there, ive seen wierder things), from there id go buy a cheapie bleed valve just to make sure your boost controller hasnt packed it in and from there id be looking at your manifold gaskets? :) let us know how you go with it
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
