I had a problem with my seat belt it wouldnt retract so i pulled the trim off and had a look. Found some interesting things (well to me at least)
First of all. What is the electronic unit near the driver side seat belt. I took it out and took photo... Whats its purpose ??? (edit:the fourth picture)
I was also interested in how the seat belt worked. There is a ball bearing that needs to sit in the correct place otherwise the seat belt will not retract. There was also a cable that was not connected, it was for the solenoid on the seat belt (edit: picture 1). It looks like the solenoid when activated (by 12v?) allows the belt to retract. What turns this solenoid on?? My cable wasnt even connected when i pulled it apart but i have now plugged it in.
I also took a photo of the 3 new guages i put in. AutoGuage's and i replaced the stock guages in the factory location.
I hope this all makes sense cos i got a bit drunk
https://www.sau.com.au/forums/topic/181545-stuff-near-driver-side-seat-belt/
good quality photos there. the ball bearing is interesting though ..how was the ball bearing oriented? that might be able to give you a clue! looks like maybe the ball bearing causes a switch to activate if its in the right orientation? maybe it releases ( loosens ) the seatbelt if the car is in a roll over.. but thats a bit of a wild guess as you can tell
Yeh the ball bearing has a cup over the top of it. In order for the seat belt to be retracted the ball bearing must be sitting in the depression below it so that the cup on top can move down fully. Its an interesting arrangement and probably the reason why it matters what angle the car is on.
The solenoid is on the other side (its in picture 1) . The solenoid does not play a function in the general use of the seatbelt ( I know because mine wasnt even connected and seatbelt was working fine). But if the solenoid was turned on it would push out and allow the seatbelt to retract no matter what. Its like some sort of overide is the belt locks up. Now... why the hell is this here? What activates it ? There are 2 wires that join up to the main wiring harness and go god knows where. It would be good to know that if the belt locks up again that i could just release it with a switch or something.
I also still want to find out what that comnputer looking unit is/does.
i wanted to say nice work with the gauges!
Are the GTR cluster gauges electrical or mechanical?
Are they the smoke faced gauges that Autogauge do, 52 or 60mm?
Did they pretty much bolt-in replace the old ones?
What wire did you tap into to get power to the gauges?
Sorry about all the questions, its just something im interested in doing to replace the old boring ones in there atm
cheers
Edited by SLIPPERY
Hi Slippery. No worries i like answering q's .. just wish someone knew the answer to mine
yep stock guages are electrical.
yep mine are 52mm Auto Meter guages. I like the 'stock' look so i used the old facia after and after a little bit of modifying the plastic they fit nicely. I just used sikaflex to keep them in place
No they do not just bolt in and replace the old ones.. i wish. Because the guages came with their own sensors i thought it best to use them. I doubt the sensors for temperature/boost/pressure would be compatible with the guages so i had to install them all. Be prepared to spend a few hours if you do it yourself. Once you get the guages mounted in there you need to give them ground and 12v, thats easy just use a multimeter and check the wiring that used to go to the stock guages for 12v Accessories. For each guage there is a green sensor wire for each that needs to go to the engine bay so you have to run the cables through the firewall to where it needs to go.
Boost Guage - They provide a new sensor and i tapped its hose into where the original boost sensor is. I kept the original boost sensor in there as well even though it would have been easier to remove it. I was worried the ECU might need to get a signal from the stock one. If anyone can confirm id be interested to know
Oil Temp and Oil Pressure guages - Both are very important to have. The Stock R32 GTR pressure guage sucks total balls so thats why i put one here (sacrificing the original voltmeter). Now you will need a 'sandwich plate' to install the sensors for oil temp/pressure. You have to buy this seperately
This one is $30 from justjap.com
Both of the sensors go into the sandwich plate and it jams between the oil filter and the engine.
Its not that hard. The main issue is trying to keep all the cabling neat and the other problem is the oil filter. Im sure anyone who has changed oil in a gtr knows the pain of working in that space.. it sucks. You really should consider looking at oil filter re-location kit.. they usually cancel out the need to have a sandwich plate and make changine oil a breeze. I am just a sucker for punishment.
well worth it. Get rid of that annoying mmhg boost guage. Get a proper oil pressure that doesnt randomly sit on 0. and looks pretty. Ohhh.. one thing that kinda annoys me about these particular guages is they go BEEEEEEEEEEEEEEEP when you turn on the ignition. Its part of some start up test procedure.. some think its kool but i thought its a bit annoying. double check b4 buy cos not all of them do it
Hey hazerb30,
In my 33, there are cables under the two front seats that I assume are supposed to be connected to the seatbelt 'socket' thing. I assume they must have been changed over for compliance??? Anyway, if you take a paper clip and short out the two pins on the cable (passenger-side is easiest, there's only 2 wires, not going to get the wrong ones), there is a clunk in the seatbelt mech. I understand that it's so it moves freely until you plug the seatbelt in, when it tightens. Could be wrong on that, but that's where they get connected to.
A little more about this here:
http://www.skylinesaustralia.com/forums/in...t&p=1924978
Excellent thank you. Very interesting.. I wonder if my seat belt locks up again if i short out those 2 pins it may release without pulling the side trim off again.
I did notice that my seat belt plug under the seat was disconnected but ive now plugged that back in as well.
Thanks mate. Michael
PS: still wanting to find out the purpose of that computer if anyone knows...
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
