Another Bov ?
well ive been looking into getting a bov and was looking at the greddy ones. will they fit to the stock pipe where the bov is now. if not what do i need to make it fit. also where could i put it and replace the pipe thats on there now. and the black rubber pipe thats going into that silver pipe what is that. if i want to replace that silver pipe for a polished pipe do i need to still have that rubber pipe if i move the bov to another location? hope thats not to confusing.
  • Replies 80
The Greddy ones will fit in the stock location, you'll need to tap two holes
As with the backfiring and stalling, if you tighten it up enough, reset the ECU and drive it for a bit you should be fine, but even then, once in a while it can stall
Also in some states in Australia it is illegal, here in NZ it's fine, but they sound pretty wanktastic so why bother, unless you are running a lot of HP and an ECU that can adjust the fuel mixture so the engine leans out when changing gear to accomodate the air rushing out of the BOV and not returning into the intake
Just add a POD filter, it'll give you the same kind of noise
i recently put an atmo bov on my crossover... car was running pretty crappy, but i went round and tightened and changed my hoses and runs well, but as R31nismoid could make it run poorly, backfire or stall, but if thats the case its a matter of adjusting your driving style to suit...
as skybarge said you can get a pod filter and block up where the bov goes... i at one stage had my bov disabled and with the HKS pod i had a mad flutter sound and loud too... but some people may tell u it can harm your turbo as the flutter sound is air getting pushed back into the turbo and getting cut up...
If anyone hasn't mentioned it already, the HKS SSQ fits in the stock location also, and sounds awesome. Has plenty of adjustment in it as well, but is an ATMO BOV.
You can also tighten it right up and get some dose happening :laugh:
Thanks,
Abu
sorry to hijack, i didnt think you could adjust the ssqv's? either way going atmo on mine the car would randomly stall(sometimes going around corners at 8o ks, very scary) but eventually the ecu worked it out and i havent had any trouble for months
Yep.
The SSQ have a screw at the top which is the adjustment screw.
If you wind that screw in it will open on higher boost/high RPM as it requires more pressure, and if you wind that screw out that will release the tension on the BOV and it will open up on a lower boost/RPM.
Its more like a bolt rather than a screw, and it has a little nut on it in-between the head of the bolt and the surface of the BOV.
Hope that helps :laugh:
Thanks,
Abu
All I know is that as your dumping the air that the AFM has already measured the ECU will crap itself regardless of the tightness of the spring. The only BOV which i have seen that tries to combat this AFM problem is the GFB Stealth where you can adjust how much air is vented to atmo and how much is plumbed back. But.... you are still dumping air the AFM has measured hence the ecu will compensate by overfuelling so causing stalls,backfires etc. Ive heard of people purchasing Fuel piggyback computers like the Apexi SAFC. If you want the noise then go for a pod but then u'll encounter another list of dilemnas.
Thanks for the info guys, i am currently having my GTS converted to rb25det and was wondering about the problems with BOV's good thread with good information, i was thinking about going to GFB stealth because of its adjustability, I will be running:
rb25DET
After market Hybrid FMIC with alloy piping, Apexi Air Pod, Apexi Full auto timer for NA and Turbo.
Recommendations?
rofl, another BOV thread.
Stock one:
Car won't stall
Car won't backfire
Cops won't defect you
You'll drive around and sound normal
After Market Vent to the atmosphere, whooshspinning twirly hurricane attention attracting one:
Cops will defect you
Cops will go harder on "jap" cars because you're another person with a big loud whoosh, trying to be a dickhead
Car will stall
Car will backfire
Car will blow flames, cops will defect you
Chicks will hear it, get instantly wet, and come running at your car wanting sex
Everyone around you will immediately think your cool and want to be your friend
You'll foul your spark plugs
plumb back is the best recommendation for everyone, atmo bov's and blocked bov's get annoying after a while and like everyone said theres not much benefits to them
i understand if you have a SR20 its a bit harder to make a return pipe for the bov, but for the skylines i think its easier to remake one cos the standard return pipe is like a pea shooter that bends and turns 100 times
Just use the fkn stock one! There is nothing wrong with itttt!!! :)
omg bro dat's so true uleh! Jus like ma cousin habib's vl. Da chick's luv it fully hectik uleh.
Thats weird... because your cousins VL shouldnt have a BOV. :D
Thanks,
Abu
Stock one:
Car won't stall
Car won't backfire
Car will stall
Car will backfire
have u got proof backing up all those claims????
cops WILL defect you regardless of stock bov if they wanted to, when i had a atmo bov i did not have problems stalling, or shooting flames, or being defected.
if ur gonna be a dickhead shooting your BOV every gear down every street passing every person, expect to get it.
but if ur smart about it (not making the bov crome so it stands out in the engine baY) and driving normally. its fine
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
