Another Bov ?
  • Replies 80
wow, never thought my thread would go there so fast. ok so one more question. i have an aftermarket hks mushroom filter on the stock intake tube. my blow off is really loud. ive got a fmic and intake head and catback. the rest is stock. i kinda just wanted to get rid of the stock pipe whre the bov sits and move the bov. i kinda also like the flutter sound.
abu, what were you talking about flutter earlier
I think you mean you want to have a flutter sound right?
remove your bov (2 bolts, 2 clamps)
cut out a piece of sheet metal the same shape as the base of your bov and drill the holes for the 2 bolts.
put that under the bov and plug it all back in as it was.
now you have blocked off your bov and it looks stock.
you will get flutter.
then, once you get annoyed of the car not acting as it should, you can easily just remove the plate under the bov and be back to normal.
why don't you just stop the standard bov leaking and leave everything the way its meant to be, bov's and flutter just mean more unwanted attention which at the end of the day will cost you more in $$ with the cops when they start defecting you (not to mention the wank factor)
or just buy the GTR bov and fit that like everyone else has said, people on here don't come on just to hang shit on everyone (dunno bout everyone but meh..) and you ask for answers and people have given you the right answers...
the best thing about SAU is that no matter what your question is, someone else has already been through the same thing, they are talking from experience, f**k the atmo bov off, don't block your bov cos you'll end up with the back of stock turbo in your muffler
gtr bov is plumback.
it can "blow off" more air than the gtst one.
but the gtst one is also good for well over 200rwkw.
GTR's have 2 bovs as standard.
they sit in the drivers side front guard.
gtst owners usually upgrade to a single gtr bov.
each gtr bov can breath more air and for this to happen, the OUTLET is larger in diameter.
to fit to a gtst, it will bolt on to the stock gtst bov position, but you will have to get a larger diameter PLUMBACK line.
NO, you can't vent the gtr bov to atmo.
not having a bov will not break the back wheel of your turbo.
if anything, it's the front wheel that "could" be damaged.
that is old skool
been around for like 5 years.
why would you buy it when you can get a screw and stick it in there yourself?
the little hole is there for a reason.
it helps to open and shut the bov faster.
if it's blocked, the car feels a little more jerky on the transition point from boost to vacuum.
as in when you back off from the accelerator in a gradual fashion (like when you drive on the street)
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
