  • Replies 80
wow, never thought my thread would go there so fast. ok so one more question. i have an aftermarket hks mushroom filter on the stock intake tube. my blow off is really loud. ive got a fmic and intake head and catback. the rest is stock. i kinda just wanted to get rid of the stock pipe whre the bov sits and move the bov. i kinda also like the flutter sound.
abu, what were you talking about flutter earlier
I think you mean you want to have a flutter sound right?
remove your bov (2 bolts, 2 clamps)
cut out a piece of sheet metal the same shape as the base of your bov and drill the holes for the 2 bolts.
put that under the bov and plug it all back in as it was.
now you have blocked off your bov and it looks stock.
you will get flutter.
then, once you get annoyed of the car not acting as it should, you can easily just remove the plate under the bov and be back to normal.
why don't you just stop the standard bov leaking and leave everything the way its meant to be, bov's and flutter just mean more unwanted attention which at the end of the day will cost you more in $$ with the cops when they start defecting you (not to mention the wank factor)
or just buy the GTR bov and fit that like everyone else has said, people on here don't come on just to hang shit on everyone (dunno bout everyone but meh..) and you ask for answers and people have given you the right answers...
the best thing about SAU is that no matter what your question is, someone else has already been through the same thing, they are talking from experience, f**k the atmo bov off, don't block your bov cos you'll end up with the back of stock turbo in your muffler
gtr bov is plumback.
it can "blow off" more air than the gtst one.
but the gtst one is also good for well over 200rwkw.
GTR's have 2 bovs as standard.
they sit in the drivers side front guard.
gtst owners usually upgrade to a single gtr bov.
each gtr bov can breath more air and for this to happen, the OUTLET is larger in diameter.
to fit to a gtst, it will bolt on to the stock gtst bov position, but you will have to get a larger diameter PLUMBACK line.
NO, you can't vent the gtr bov to atmo.
not having a bov will not break the back wheel of your turbo.
if anything, it's the front wheel that "could" be damaged.
No the stock gtst ones don't leak after 10 psi.
No it doesn't matter which gtr bov you get.
expect to pay about $150 for the pair or half that if someone is selling one.
http://www.skylinesaustralia.com/forums/in...howtopic=181922
Or you could buy this!
that is old skool
been around for like 5 years.
why would you buy it when you can get a screw and stick it in there yourself?
the little hole is there for a reason.
it helps to open and shut the bov faster.
if it's blocked, the car feels a little more jerky on the transition point from boost to vacuum.
as in when you back off from the accelerator in a gradual fashion (like when you drive on the street)
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
