hi guys thort id try and pick your brains and see if anyone knows much about air con in these skylines.
when I change from the different settings from demister to feet it makes a click click clack noise from somewhere it sounds somewhere at the top of the dash, I have done a search and apparently it is the plastic cogs on the stepper motors, whats involved in getting these stepper motors out??
Also when switching the climate control it is only cold at 18 and the rest are all warm which is annoying, I have done a diagnostics on it and its coming up with
outside air sensor
inside air sensor
sunload sensor (not sure if this would be faulty because I did the test when it was in my garage.)
How can I find the other 2 sensors? and how can I test them?
Any help would be much appreciated, im sure with all the r33's around theres gota be someone whos had these probs aswell.
https://www.sau.com.au/forums/topic/181553-air-con-probs-r33/
It seems that I have the same problem as you. (you can only turn the stereo up to cover it for so long lol)
Im really keen to find out what is involved in getting to the controls.
Somone here had an english workshop manual maybe there might be some help in there??
Jason.
should be the same for r33 in my car the sensor in a little vent to the left of the steering wheel was disconnected which caused problem u described, could be any of the sensors thou....cold air at 18....anything more it went hot. also when u did the diagnostic did it tell u the temp the sensors were reading were they all similar? because my the faulty sensor in mine was given a really different reading......as for the noise i get that too is abit annoying!
Edited by rgr34
I've found I can stop the clicking if I leave the air on face and feet all the time... then it doesn't click when I start the car. It will still click when I turn on the climate control or change the direction of the air, but by then the stereo is on. Bloody annoying but from what I understand its a whole days work removing the entire dash to fix it then put the dash back together. maybe I'll fix it one day... maybe
The sound you guys/girls (if any) is the sound of the gears slipping on each other when you're trying to change the direction. The gears have probably just worn out over time. To change it, I think you have to take out the whole dash to get to the heater core.
I dont mind doing that as long as I know what Im doing once I get it off and can get the parts to replace them.
Not looking forward to pulling off dash and then having to put it back together if I cannot find out what the problem is or source parts.
I'm not positive that your problem is the gears, but I heard it was common problem on the 33's heating system. I'm just giving you ideas mate. I don't want you to rip out the dash and found nothing wrong inside. Taking the dash out seems like a huge job.
that sounds like my issue. the gears, mine only does it for 5 seconds when it turns on or off.. dash is easy. just need to find the gear thats clicking//:action-smiley-069:
Hey mate thanks for that, have the cover off and the only thing that leads to that vent is a pipe.... so does this mean the sensor is missing or is it in a different place?
hey mate in my r34 there is the plastic pipe u describe and another plug for sensor connected in........ someone with a r33 needs to confirm its the same.......i would imagine it is thou....the plastic pipe connects to the back of the unit and the from memory the plug is on the side u see anything like that?
same issue as above, but only for around 6 clicks, but then if you listen closely espcially in the mornings i can hear like "water running down the sink" sound coming from the engine bay???? could be related to the air con issue im not sure. wondering if anyone has heard a simular thing??
guys it it the motor on which switches the vent over, mine does the same thing but I have got a second hand motor and just have to find the time to be stuffed to pull the whole Dash , cluster ...pretty much everything aroundthe dash to get to the motor.
5-6 hour job I believe....I will get around to it some day......car is only driven on the weekends anyway!
Hey thanks man yeah it would be good if someone can confirm if there is a sensor there because that must be the climate control problem if it is missing, seems abit werd tho because there are no wires there or anything.
cheers.
Some say that it'll take about 6 hours, some say that if you know what you're doing, it'll only take 1 hour. I think it's best to get someone who's taken out the dash before to help save some time.
Yes it does take 4-5 hours..
Its a big job taking the WHOLE dash out..
thats right, you gotta take everything off..
This guy had pics up here on how to take the dash out: http://gtr.ferni.net/misc/dash_removal/
BUt seems like the link isnt work anymore :(
"ferni"-- hmm that name sounds familar.. im pretty sure hes on this website..
hope he sees this
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
