As described, it has come time to upgrade the brakes as to be legal after the engine and gearbox transplant. The car has 4 stud hubs and non turbo brakes at present. Speaking in an engineering viewpoint, do you "HAVE" to upgrade the hubs to five stud? Obviously the calipers are going to be upgraded from GTS to GTS-T front and rear.
Am asking as I would like to keep same wheels on car etc. I will probably upgrade rotors to go with the caliper change but want to maintain four stud!!
All you engineering gurus out there give me guidance please!!!!!!!
https://www.sau.com.au/forums/topic/181556-brake-upgrade-on-ex-non-turbo-33/
As long as you can get brake discs to suit I see no reason to go 5 stud, just so long as the wheel contacts the locating shoulder to take the load from the rim instead of the studs doing both jobs.
here are my brakes.
redrill the rotors
dba will sell pre-drilled blank discs
just ask them for the one specific to the caliper your upgrading to
Does that slow bucket of shit need brakes Eug. :laughing-smiley-014:
DBA use their silly kangaroo paw crap, from an aero pov that is nasty, then there is the structural analysis that I see as being the flaw behind the reported cracking, then the poor slotting design that seems to result in uneven disc wear, then ..... well the list goes on. I'd suggest critical flaws in the metallurgy as well in light of some of the above as well.
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
