Okay guys, I got a problem. I have been banging my head on the wall for a full day of diagnosis.
The car is a Hybrid monster. Its a RB25 engine with RB26 rods pistons ect. Its think it's got a RB25 eng harness but since the engine was in a Cefiro some things have been changed and I cant even really confirm that it is a RB25 or a RB20 Harness that ran this thing. It ran a whole season with a RB25 Apexi PFC but since my bud wanted the D-Jetro he got a RB26 D-Jetro box to run the thing. We have now built the engine and when I start it up I don’t get the no 1 and 4 injector to fire.
I’ve gone through the pinouts a million times and everything seems to be pretty good. I tossed in a RB20 ECU to see if all 6 would fire and they do. So I then tossed the RB26 PFC into another GTR to see if the injector driver was messed but when I tossed it in she ran fine. So I know the box it fine.
When I toss the probe on the injector pins on the ecu "101, 105, 103, 114, 110, 112" They seem fine as the probe switches back from 12V and earth.
When I toss the NOID LED light on the injector plug no 1 and 4 don’t light up as bright as the rest. They do light up but not full out like the rest. I have checked resistance between the ecu plug and the injector plug and everything seems fine with all the connections in between.
All 6 injectors are good and tested just yesterday. All settings are set up properly with them too. We are not running the VVT anymore.
I looked at the differences between the 20/25 ecu pinouts and the 26 pinouts and there were some differences so I figured I might be getting a voltage signal to the ECU that’s not meant to be there so I removed the pins that were blank on the 26 pinouts to make sure I wasn’t getting any voltage feedback.
I am stumped. Any help is appreciated!!!!
https://www.sau.com.au/forums/topic/181567-injector-no-1-and-4-no-fire/
KK Guys, I figured it out. Took the harness apart and cleaned it up and found that the front MAP sensor was pined wrong to the maf earth and not the signal. So ya. Stupid lil problem that took an entire day but its all good. The car runs and I can go eat some taco's now. Night!
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
