anyone know why this is the contrast works fine & reads everything but no backing light cleaned contacts around plug area it had a bit of corrsion around plug that sits on board cleaned it all up but to no avail does anyone no if theres a solution to the problem Cheers
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/
mine is doing the same thing.
If you flex the hand controller a little (ie bend it either way) does it light up?
If you find out who can fix it, let me know asap!
nope not at all im going 2 see a mate thats an auto electrician see if he has any answers
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3297851
mine is doing the same, brand spanking new!
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3297884
issues with the hand controller. has anyone pulled one appart and tried to fix it yet ?
AH this is the mystery sent it back & they tried it on there powerfc worked fine must be something to do with powerfc itself maybe plug faulty
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3298032
ive heard of this issue, the only logical thing i can think of is somehow the internal power source for the backlit is toast on the FC itself
but that makes no sense because i can power up a hand controller off a usb port and the buttons and display get local power from the same wiring
so i have no idea
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3298135
so i have no idea
how did you get it to power up from a usb port?
Please explain this, as I'll be able to sit down and fix mine by simply plugging it into a USB hub or something, without having to get in and out of the car to test it.
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3298370
hey
i cut the plug off and just played guess the wires and eventually got it
it just needs 5v + and negative to crank up
it wont boot to the apexi logo as its waiting for CLK and check signals but the lights come on
you could if you really wanted get a PS2 female cable, chop the end and wire it to a usb plug
that way you dont have to cut the end off your normal good working hand controller
i just chopped the end on my one as it didnt care about it cos it was already toast
let me see tonight if the usb plug is still fitted, i could get the pin out config if i do so u can do it yourself
just be careful not to bridge the wires otherwise windows disables the hub and you have to reboot (well i did cos it has my mouse on it)
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3298381
hey
I plugged hand controller into computer but still no backing light the apexi logo comes up though maybe the hand controller lcd stuffed god only knows
https://www.sau.com.au/forums/topic/181569-apexi-power-fc/#findComment-3307622
