  • Replies 94
Adam,
Shaun at boostworx is knowledgeable in all things RB, so I would suggest him for sure. Cost? Well an inspection for my car was going to be ~$120 prior to purchase but he was rather booked out at the time so I went to Hi-Tech Dyno.. I would MUCH Rather have waited for Shaun in hind-sight.
Hope this helps :D
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297709
As above, Just take it to a reputable performance workshop.
Depending where you live Boostworx=South Wilall=North
Ryan
just another thing, is $25 to $28 the right price for 33 gtrs now or is it cheap??
I dont kno wheather to be wary or not...
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297762
Tilbrooks would also be an option!
On that note though even if you get 100 different reports there could stiull be something wrong with it.
Not to deter you or anything... But yeah just make sure you have a decent amount of cash always put away "JUST IN CASE"
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297825
Also looking at a R32 GTR
Anybody got any pros and cons of getting a R32 GTR or a R33 GTR?
also anybody owned either of these? would like to ask a few questions...
cheers
i own a 32gtr, and most of the good con 32gtrs are around the $22,000 mark (i purchased mine earlier this year)... so $28 seems kinda round the mark i'd expect from a 95-ish r33 mebe a bit on the cheap-ish side of things
i'd also recomend shaun from boost worx, he's helped me out lots
questions???
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297829
questions???
just with th 32 what things have u had to replace, repair, fix etc cos obviously there getting old... and i have heard some bad stories and exspensive stories about the diff and the oil pump etc...
but yer
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297839
Things to replace/maintain: everything included in a 100k kms service, if you are unsure of true km's which most will be, suspension bushings are usually shot to hell(well mine were), rubber boots (gearbox, driveshafts, suspension), suspension if it is still stock as they are so old. Get your pumps tested and replaced if they're not flowing (they are suprisingly tough though). Window seals are usually bad as well, my boot fills with water, I just don't store anything in the boot.
Oh, and get your car doors reset as they're usually sagged...I still haven't gotten around to doing mine :D
Edited by ecenshu
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297848
is this the type of thing boostworx can pick up if i take it there before i buy?
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297855
Some of what I listed can be picked up with just a visual inspection, however some things need manual labour to test and will get charged for. Compression is usually a no brainer but leakdown and flow testing pumps etc should cost something. A lot of the stuff in my car I only picked up as I owned it, couldn't really get a thorough inspection done in Japan since mine was imported.
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297882
oh ok yer i have emailed boostworxs to see what they look for if i bring a car in for an inspection
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297890
but yer
actually nothing has gone wrong with my car, its coming up to its 100,000km service, so im going to get it done properly and actually replace the oil pump with an n1 oil pump and get the sump modified, shaun from boost worx has got some kinda techniqe he uses to do it heaps cheaper than anywhere else in adealide, basically i e-mailed EVERYONE on the workshop listing as well as a few others, boost worx was the ONLY place to give me a full itemised quote with everything explained, didnt question any crazy request i had and didnt say "bring it in to get it looked at"
but things i have had done to it: re-shimed the valves (i think this is recomended to get done ever 40 to 80,000kms depending on how hard you drive the car) as well as a leak down test and a power run to check mixtures etc. also had a lot of it visual inspected by the guys from boost worx, including suspension. havent really needed any major repairs nothing critical has failed, one of the O2 sencors was a bit dicky but has come good recently, the air-con needs looking at, but i knew that before i bought it and there are no other issues lurking. so far the bill has been around $600 - this includes $100 to attempt to silence brembos =P
it all depends on how hard your gonna push it from the time you get it... if your an experianced track racer that is going to take it out the week you get it, then you could be looking at some issues, but if you have the time to make sure things are in order first, then they will be no worse off than a 33 imo - infact slightly better :D
hope this helps
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297917
hope this helps
cheers for that... what were u quoted for the oil pump??
Also has anyone had a noisy diff fixed?
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297932
cant give you exact price on the what it would cost he quoted labour for the whole job + individual parts prices, the pump itself was around $600 but i have no idea about the labour involved, soz
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297963
ok no problems because i have heard some scary $$$ figures
https://www.sau.com.au/forums/topic/181578-gtr-sale/#findComment-3297986
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
